Old 09-05-2006, 07:32 PM   #1
dharhigh1
Radiator over flow bottle?
My truck doesn't have an over flow bottle and I was wandering if I need one or not? I checked my fluid in the radiator and it was about half a gallon low, it also has a new huge after market radiator in it.
Do most of you have the bottles in yours?
Thanks,
dharhigh1 is offline   Reply With Quote
Old 09-05-2006, 08:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Radiator over flow bottle?
they did not come stock with bottles, but there was a dealer installed option avalible. I mounted a 2nd washer bottle on mine, and a rad cap from a later model truck was needed, and it works great.
Old 09-06-2006, 01:29 AM   #3
nate68
i bought a generic one and it works fine. a definate must if you ever want to race
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-06-2006, 03:51 PM   #4
longhorn70gmc
longhorn70gmc's Avatar
I have one in both trucks. I think it is needed.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 09-06-2006, 03:54 PM   #5
c10crazy
Like a Rock!
c10crazy's Avatar
just curious, does it suck the coolant back to the radiator or just sit in the overflow?.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 09-06-2006, 05:08 PM   #6
Longhorn Man
If you install the later model cap, and have it plumbed properly, it will draw the coolant back in when it cools off.
it isn't really needed, the coolant level (pewr owners manual) is supposed to be an inch or so below the top of the rad.
Old 09-06-2006, 05:24 PM   #7
neonlarry
neonlarry's Avatar
This is what I pit in both of mine. Out of an 80's G-Body.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-06-2006, 05:39 PM   #8
SOON2BLAZE
SOON2BLAZE's Avatar
Thanks larry! I called my local gm dealer and the G body ones run about 20.00 looks better than a walmart one too.
SOON2BLAZE is offline   Reply With Quote
Old 09-06-2006, 08:00 PM   #9
RSRXION
RSRXION's Avatar
That's the same puke tank that was in my 72 hauler. Is a G body a Monte Carlo / Regal / Grand Prix etc... ? What's the part number on the top ? Mine was very brittle and fell apart when I removed the inner fender. Thanks, Dean
"They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Ben Franklin
RSRXION is offline   Reply With Quote
Old 09-06-2006, 10:19 PM   #10
neonlarry
neonlarry's Avatar
I don't see a part# but yes G Body= Monte etc.
Old 09-07-2006, 12:04 AM   #11
Southpa
Southpa's Avatar
I'm using one from an '82 camaro, it fits well on the inner fender.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 09-07-2006, 02:21 AM   #12
jimmydean
jimmydean's Avatar
I got one off a Suburban that I puller some other parts off of. I have the wrong cap, so it doesn't do anything but take up space.
jimmydean is offline   Reply With Quote
Old 09-07-2006, 09:54 AM   #13
mbgmike
They weren't needed on the older vehicles until the government started requiring them. Glycol doesn't evaporate and they didn't want it all over the place making a mess
mbgmike is offline   Reply With Quote
Old 09-07-2006, 02:44 PM   #14
Southpa
Southpa's Avatar
I only installed an overflow tank because, at the time, the bottom 1/4 of my rad wasn't functioning. A couple long trips thru the mountains, with temps reaching 260 degrees, pretty much caused a LOT of coolant loss by the time I reached my destination. Its a wonder that the engine even managed to stay together after all that.
But with the proper rad cap and thermostat installed coolant loss should be negligible on these old trucks.
Original 350/TH350
