Old 09-05-2006, 07:34 PM   #1
uk72step
outta the car velocityboy
uk72step's Avatar
c10/c20 lower A Arms
Hi guys,
Does anyone know if the C10 and C20 lower control arms are the same or interchangable? They look pretty similar. Anyone know the answer to this?
My parts interchange manual says they are not but they do look very similar (except one has two holes drilled in the base near the sprign mount(Shock mount bracket holes?)
Cheers
Lee
..give it a turn here, take some wedge out there, we'll win some races...
uk72step is offline   Reply With Quote
Old 09-05-2006, 08:17 PM   #2
uncle
Re: c10/c20 lower A Arms
The c/20 should have a larger hole for the ball joint. The half ton ball joint will fall through the hole in the 3/4 ton.
uncle is offline   Reply With Quote
