Old 09-05-2006, 09:55 PM   #1
mothertrucker424
mothertrucker424's Avatar
72 w/ stock rims and 33"s
i'll start by saying i have a 72' k10 bone stock i wanna put a set of 15x12.50x33 tires on stock rims and maybe do a 2"boost (blocks maybe) but i need to know what size back spacing on stock steel wheels i will need to fit tires on truck????
thanks
mothertrucker424 is offline   Reply With Quote
Old 09-05-2006, 10:55 PM   #2
Re: 72 w/ stock rims and 33"s
Why not get BFG 10.50/33s or I think they make 9.50/33s,too.
Old 09-06-2006, 06:43 AM   #3
vtblazer
vtblazer's Avatar
Run a set of later model factory rally's and you'll be fine.
4" back spacing seems to be the magic number.
vtblazer is offline   Reply With Quote
Old 09-06-2006, 08:42 PM   #4
mothertrucker424
special K i already have the tires from a project
vtblazer do you have any recomedations??
and also can i use jeep wagoneer wheels?? or are thay not back spaced enough??
Old 09-06-2006, 10:16 PM   #5
Southedisto
River life......
Southedisto's Avatar
255/85-16 =33" tires
Southedisto is offline   Reply With Quote
Old 09-07-2006, 12:22 AM   #6
Those rallyes are all over the place.Keep an I on the parts section of classifieds.
Old 09-07-2006, 03:49 AM   #7
vtblazer
vtblazer's Avatar
Yep...
Old 09-07-2006, 06:48 PM   #8
mothertrucker424
i take it that the wagoneer wheels won't fit??cause i can find them in the scrap yards a dime a dozen....till i can decide what wheels i really want or can afford
Old 09-08-2006, 12:42 AM   #9
1969K10
1969K10's Avatar
If you can wait a little longer, I got 15" ralleys that I won't be using much longer, with just under 1 year old BFG AT 33X10.5X15. I'll try to get some pics.
1969K10 is offline   Reply With Quote
Old 09-08-2006, 07:53 PM   #10
see ten
WTB this ad
see ten's Avatar
Aren't Jeep Wagoneer wheels 5 Lug? Your K series truck should be 6 lug.
see ten is offline   Reply With Quote
Old 09-08-2006, 08:05 PM   #11
Southedisto
River life......
The waggs were 6 lug.
Old 09-08-2006, 10:57 PM   #12
mothertrucker424
ya the full size waggy is 6 lug but i dont know if they would help with 33x12.5's
Old 09-09-2006, 01:13 AM   #13
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a '71 Jimmy K/1500 [same as K/5 Blazer] that is the stock height -- not lifted-- and I run 33x12.50R15LTs on 15 x 10 chrome spoke wheels. Don't need a lift. I just got a new set of Dunlop A/T Radial Rovers today. [My old tires were blowing out like water balloons] They don't rub, even in a tight turn.
I also used to have a '67 K/10 Suburban, again with 33x12.50R15s on 15 x 8 white spoke wheels. If it was really loaded down I'd get some rubbing in the rear wheelwells when at speed on twisty mountain roads. [Stock Stance] But usually it was fine.
Old 09-09-2006, 07:20 AM   #14
Try to find my favorites.Stock center 8x15 rims.You can keepthe stock look while adding some beef.They were used,most recently,on CUCV Blazers.But,have been around forever.
Old 09-09-2006, 07:52 AM   #15
mothertrucker424
i'd love to keep the stock look how will i know what the 15x8's look like and you say the blazers right
p.s.-what is a decent lift co.? should i go with add a leaves or full packs or blocks or shackle flip??????so many options
Old 09-09-2006, 08:09 AM   #16
msgross
msgross's Avatar
blocks should be your last choice unless you need to save $$$.
msgross is offline   Reply With Quote
Old 09-09-2006, 08:50 AM   #17
mothertrucker424
i figured old leafs + blocks = break or sag
and body lift is out till i need engine space (also body lift looks cheap and unsafe)
Old 09-09-2006, 10:10 AM   #18
1969K10
1969K10's Avatar
Mothertrucker, here's some pics of my wheels. i'll also send a PM
Old 09-09-2006, 10:19 AM   #19
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Where are you in Florida, you should put the city in your profile.
BTW I used to run 15x8 Turbine wheels with 33x12.50 and no lift on an old Blazer I used to have. No problems.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-11-2006, 12:15 AM   #20
Down south truckin
Down south truckin's Avatar
hey mothertrucker424 i have a couple sets and i have a friend that has a couple sets of the military 15x8 stockers if you decide on those we are about 15-20 miles N/E of Atlanta let me know and i'll try to get some pics Mike
Down south truckin is offline   Reply With Quote
Old 09-11-2006, 12:19 AM   #21
Down south truckin
here is one set i have on a 69 swb4x4 the tires are 31x10.50 hope this helps Mike
Old 09-11-2006, 12:22 AM   #22
Down south truckin
here's a set on my farm truck it also has 31x10.50s Mike
Old 09-11-2006, 06:51 AM   #23
That`s the ones.I`d like to get a set for my shortbed.
If you want to stay stock,as in not wide tires,there are 6-lug 16" wheels that these trucks came with as an option.You can mount 285/75s of 255/85s on them.
Is there still a 4wd lift/tire combo sticky?
As for lift...spring lifts give new springs to an old truck.A no-brainer,unless your truck has been real pampered.As for blocks,I have no problem with 2".I`ve never had a problem with 4" blocks for that matter.There`s alot of hype about axle-wrap.If I was on a magazine budget recieving parts for free or nearly nothing,I`d do everything like the mags,I guess.
Old 09-11-2006, 07:28 AM   #24
mothertrucker424
i have decided on a 6" lift just not what brand yet and as for wheels i want a steel wheel (15x8-10)that my factory hub caps will mount on and still be able to use my 33x12.50 tires
