Old 09-06-2006, 11:45 PM   #1
sganje
rear bumper pics?
Anybody have any pics of there rear bumper with spare tire carrier? I think I am going to try and make something and would like some ideas before I start. How thick of steel should I use? Please post some pics thanks.
1970 Blazer 4WD
fixing rust. Does it every end!
sganje is offline   Reply With Quote
Old 09-13-2006, 12:22 AM   #2
sganje
Re: rear bumper pics?
Nobody has a rear bumper with a spare tire carrier that isn't stock? I thought I might get at least 1 pisture. Thanks
1970 Blazer 4WD
Old 09-13-2006, 08:08 AM   #3
tpi72blazer
Tpi72Blazer
tpi72blazer's Avatar
Contact BobbyK - he has one he built for his Blazer which is very nice. If memeory serves, he even has blueprints to build one.
Indian - the other money pit
tpi72blazer is offline   Reply With Quote
Old 09-15-2006, 08:23 PM   #4
sganje
thanks
1970 Blazer 4WD
Old 09-16-2006, 08:02 AM   #5
Drink2many has pictures on his Blackbird's link.
Old 09-18-2006, 12:13 AM   #6
earl87gta
earl87gta's Avatar
I have a cool one that is for a stock bumper it bolts in between the bumper not the body and has gas shock that lets you lower it down so you can lower the tail gate it will hold a 35in tire with no trouble . I don’t have it on my blazer right now blazer is tore down an getting a face lift but I if you think its something you would like to see Ill snap a pic of it for you
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-18-2006, 01:34 AM   #7
71jimmy
71jimmy's Avatar
YEAH, YEAH, YEAH, would like to see. Tell us were you got it also.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-18-2006, 02:54 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-19-2006, 11:13 PM   #9
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I didn't build the bumper...just the tire carrier.
That's a 33" tire mounted to it.
Click HERE to see ALL the pic's I took while building the carrier.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-20-2006, 06:27 AM   #10
vtblazer
vtblazer's Avatar
Here's another version of the same thing.
That's a 36" spare mounted on it.
vtblazer is offline   Reply With Quote
Old 09-22-2006, 02:00 PM   #11
Burt4x4
Burt4x4's Avatar
I built mine...made it hold the tire higher up as I was allways draging my spare with the old gate I had..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-22-2006, 04:31 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by Burt4x4 View Post
Cool, it made a perfect home for the hi-lft jack
Old 09-26-2006, 02:29 AM   #13
earl87gta
earl87gta's Avatar
Soorry I havnt got you pics yet if i have time Ill take a few tomarrow for you. only problem is I dont have a stock bumper to set it up aganst so it may be hard to tell how it mounts. but it is a cool set up instead of swinging a way to the side it drops down like the tale gate and uses a gas shock to make it easy to lift and lower.
Earl
Old 09-27-2006, 12:25 PM   #14
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
This one is on a blazer I am still trying to buy.....
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-28-2006, 02:05 AM   #15
earl87gta
earl87gta's Avatar
Here is a link to the tire carrier I have its kinda cool no holes in the body needed. It bolts to the bumper you can use one bumper bolt but you need to drill one too . You will also need to drill one for the pin that hold it in place when up. But I would rather change a pumper if I get tired of it then have to fill holes in the body and paint .it folds down like the tale gate does . Im not sure who made it but it is a universal fit you can move the lugs to fit any wheel . The gas shock is strong and makes lifting the tire easy. I was going to take a pic with it in the down position but I couldn’t hold the crow bar and take the pic. It will hold a 35 in tire so it would be great for some one with 33s it looks like it would be easy to make theirs not a lot to it.
http://pg.photos.yahoo.com/ph/earl87...owWkFBSlnhH3zd
Earl
