68 grill fit a 70 hood?
Will there be too much gap?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: 68 grill fit a 70 hood?
it will not fit, unless you do some major fabricating, or unless it is a GMC.
It fits, but has a "hellacious" gap. I have pictures of mine when I swapped it over, that I'll post when I get home from work
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
There is like a 1 1/2 inch gap because the 67-68 chevy hoods are shaped differently
Looking forward to seeing the pictures. Hate to drive a truck with a huge dent in the grill when I have a perfect 68 grill with all the chrome making dust and letting the hummingbirds use it for a perch!
Here's the pics... I know you can't see it TOO good since I had painted the 68 grill black before I put it on, but there is a piece of cardboard behind the grill that kinda highlights the gap. It will fit and latch if you have to do it for some reason, but looks like crap IMO.
i am going to have an extra 69-70 front clip.i bought a 67 4x4 that someone has installed a 69 front clip.am looking for pieces to replace and put it back 67 or 68 front end.i dont have the truck home yet but hope it want be too long.i have a friend bringing it from col to ark.might be interrested in a trade if distance isnt too far. marvin
If your entire truck is a 70, that 68 grill will not work with your fenders either.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#9 | |
![]() Another thing that I think needs to be pointed out is that the radiator supports put the headlights in different positions for the 67-68 and the 69-72, so you can't use the headlight trim rings if you don't swap that out too.
Hmmmm I had a 68 rad support beside the 71 GMC rad support with the exception of the dual headlights I didn't notice any alignment with buckets..One thing I did think was the GMC rad support seemed alot heavier than two additional buckets for the headlights. But it could have been my imagination..I had been moving railroad ties around in the yard everything seems heavier after movin a dozen of them.
The GMC rad supports were the 67-68 style with the dual headlight brackets spot welded on. The 69-72 Chevy supports are the different ones. I actually used a 68 GMC rad support that I cut the spot welds off of.
