09-07-2006, 10:32 PM | #1 |
carb removal
I am installing a carb space. I am thinking remove all vaccum lines fuel line throttle rod remove carb. Clean then put on new gasket spacer gasket carb. What is the torque on the studd bolts? Should I use anything on the gaskets? anything else I should do when the carb is off?
Any other thoughts on the subject?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
09-07-2006, 10:53 PM | #2 |
Re: carb removal
If you have never done this before, take a number of photos before you start. Gaskets go on dry.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
09-07-2006, 10:59 PM | #3 |
Re: carb removal
Holley says 60-80 in/lbs and do it in a cross pattern, like rims. If your vacuum lines are getting hard and brittle then you may change them. PCV too...
09-08-2006, 07:55 AM | #4 |
Re: carb removal
You mean take a pic of the throttle linkage and vac lines for reference?
09-08-2006, 10:12 AM | #5 |
Re: carb removal
Right
09-08-2006, 10:48 PM | #6 |
Re: carb removal
When its all said and done if you have extra parts you know its done right
1970 Short Stepside----Process of Restoring 1983 1/2 Silverado |
09-08-2006, 11:18 PM | #7 |
Re: carb removal
Tighten your carb down a little at a time. You don't want to crank one down to prescribed torque and then move on to the next one. ( good way to break an ear off of the carb?) My $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
