Old 09-08-2006, 06:23 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Alignment Specs
I'm taking the 71 C10 2wd LWB in next week to get the front end aligned. Instead of relying on them to get the specs right I'd like to give the specs to them. If anyone could direct me someplace to find them or if someone has them it would be much appreciated. Thanks in advance!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 09-10-2006, 01:42 PM   #2
jasonrmorrow
Re: Alignment Specs
Camber - .25 + or - .5
Caster - 2.5 + or - .5
Total toe - .30
Original toe specs are for bias plies, so you don't need as much toe, I adjusted the specs to what i aligned mine to. I went with .3 total toe,
if you search back under my name there will be a picture of my alignment sheet.
By the way these are 63-66 specs, should be the same, i'll grab 67-72 just to be sure on monday.
EDIT**** Specs are the same thru 73, only thing that changes is caster moves up to 2.5* and then back down, get caster above 2.0 and even and you're good to go.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 09-13-2006, 02:08 AM   #3
Draggn66
Draggn66's Avatar
Re: Alignment Specs
Thanks for the info! It's better going in prepared and not gambling they get it right.
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
