Re-Pop...jeez...should be call Re-Fit!
Well today I had the inkling to work on my truck again, so I decided to install the passenger side inner fender. My fenders are Tri-Plus and so are the inner fenders, radiator support is GM original. RE-POP should be called RE-FIT. What a challenging Mother F'en Beeooch, pardon my language. I will say I learned my lesson and will pre-fit every and all parts prior to Paint, next time!!! I could have drilled out and enlarged holes here there and everywhere, and stretched out the metal first which would have made life simple. Live and learn. If you are using RE-POP make sure you fit them first. I will win...but it could have been much easier. Have to say this goes back to my 1st painter who did not pre-fit my truck prior to paint.
YA YA
Re: Re-Pop...jeez...should be call Re-Fit!
Man that blows. Truck is looking saaawwwweeet! I really like that color.
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 |
![]() Join Date: Aug 2001
Looking Good Alex. Repop Parts Are The Bunk. I'll Use Original Oem Sheetmetal When Ever & Where Ever I Can.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Thanks Jim and John. No kiddin...re-pop = re-sheot
![]() Join Date: Oct 2005
Yelp, engine compartment looks great and it confirms that I'm painting my inner fender wells the same color as the exterior.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
computer illiterate
it was ticky but i installed mine with no real problems i put the big bolt that goes in the cab in first and then the center wheel well bolt followed be the bolts that go in the core support (they where all left loose) and then went around the wheel well installing the rest of the bolts and they actually went on pretty easy and im not standing up for repop as i hate them too and use nos most of the time
72 2wd blazer 72 swb 4x4 |
Anyone have a pic of knows how the square hole in the back of the inner fender next to the frame where the large bolt goes into the frame...Is there a square piece with a hole in it, that fits in this hole???
Man that sweet under the hood!! Nice work!!!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 09-09-2006 at 01:46 AM. |
#9 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Cool...that makes sence.
Looks great under that hood.I remember when re-pro was non-existing.We were glad to have it when it hit the scene.Now,we cuss it and wish it away,go figure.Body fitment has never been a "bolt-on" experience.When it is,you`re lucky.An old rule with car building is get it together,work out the bugs,then disassemble for paint.That`s where the whole "In suede" thing comes from we see on ratrods and other projects.I`m just glad to see a quality stamping.If we can "make" them work,that`s all I ask.Maybe it`ll get better,but I doubt it.At first,they were saying repro would kill the used part market.Ain`t happnin`.
The LuvShack Garage
I deceided to do this last year, I went ahead and assembled my whole
front clip knowing it would just have to come apart again before paint, the drivers side re-poop inner fits pretty decent, but the passenger is a pain in the arse, I am glad that I did try to fit everything in advance, I found several minor issues, I still haven't fixed, that would scratch up the fresh paint, I still haven't done, when she someday gets finished ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#13 |
WTB this ad
Are the inner fenders no longer available through GM? The last ones I bought I got from the local Chevy dealer.
#14 |
The LuvShack Garage
Never knew that, wish I had known before I bought mine
#15 |
There are actually shims that go behind the inner fenders where that back bolt goes in. They need to be there or if you tighten them down tight the hood lines will get al messed up.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#16 |
![]() ![]() Join Date: Jul 2002
My inner fenders were both a pain when I was trial fitting them. One was OEM, one was aftermarket. Both required lots of patience. I hear the inner fenders are the worse of any piece for inconsistencies.
#17 |
2WD Jimmy
![]() Join Date: Mar 2005
I had to replace my passenger side because of battery rust. I got an OEM from Brothers... it just droppd in, no adjustment whatsoever. I had to buy a repop grill because the plater ruined my original... MAN... what a PAIIINNN! (but its finally in)sigh
#18 |
sufficiently talented fool
![]() Join Date: Jun 2006
Truck looks great!! ( understatement ) I had a little trouble with my inner fenders also, but with time & patience, you will win ! Keep up the good work !
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
#19 |
I will win...I do know that...was just saying what a pain this repop stuff is. Next time I will pre-fit everything. It just would have been easier that way. Will I use it again....yes if I have too. Thanks for your nice comments on my truck.
Alex |
#20 |
The LuvShack Garage
Yeppers, I bet you will, and I bet a BFH might be involved
#21 |
Can't use a hammer at this point. LOL!!! Those inner fenders were $325.00 a piece to paint. The chrome plated ones you can buy seem like a good deal when you add the cost of the re-pop inners and then the paint!!! I think the red looks better than the chrome would have ....JUST should have pre-fit!!!! I'm going to remove the battery box (there is a bolt there that doesn't line up) and then I need to enlarge the two outside front holes and the bottom wheel arch hole. Can you say P-I-T-A!!!! And say it loud!!! LOL! But.....I will win!
#22 |
You can still buy the inner fenders from and gm dealer across the country.
#23 |
#24 |
Well I just found them...click the Restoration tab on top:
Link to web site: http://www.gmpartsdirect.com/ -------------------------------------------------------------------------------- GM PART # 3882650 PACK QTY: 1 CORE CHARGE: $0.00 GM LIST: $199.04 OUR PRICE: $122.13 DESCRIPTION: INNER FENDER RH -------------------------------------------------------------------------------- GM PART # 6270855 PACK QTY: 1 CORE CHARGE: $0.00 GM LIST: $226.52 OUR PRICE: $139.00 DESCRIPTION: INNER FENDER LH Last edited by ChevyDude; 09-09-2006 at 01:21 PM. |
#25 |
WTB this ad
I noticed they also have mirrors, grills and inner grills listed on that link.
