09-09-2006, 07:20 PM | #1 |
It's Done When It Runs!!
Help! Need Engine Advice
I am going on deployment to Iraq at the beginning of the month. That means I will be able to save a few bucks while over there. I have a moderately used 350 in a 71 LWB right now and an egine builder connection. I would like to get one of those Vortech or ATI supercharger setups with the blow-through carb in the near future. My question is should I have the engine built with lower compression with parts suitable for a blower or should I save the money to get the blower when I get back and run a lower boost 3-5 psi? Thanks in advance for all of your adivce, any is appriciated.
Jake
Or Give Me DEATH |
09-09-2006, 08:04 PM | #2 |
Re: Help! Need Engine Advice
lower compression always, you will hate having a huffer and only running a few lbs of boost.
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
09-09-2006, 11:48 PM | #3 |
I agree. Run lower compression if you are going to install a blower. Even with only 3-5 p.s.i. of boost, ignition timing is going to be real touchy with high compression pistons. Be careful over there! And remember, most of the country supports the mission, and think you people are doing an outstanding job.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-10-2006, 07:44 AM | #4 |
yeah, low compression. youll get better performance by being able to go with more boost. you'll be disaapointed if you can only run 3lb's. after spending all that money you want to run it like its made for.
09-10-2006, 07:45 AM | #5 |
e-mail me when you get back. ill help you install it if you like.
09-16-2006, 11:57 AM | #6 |
Thanks for all of the support and advice. I will be able to get the motor set up the for a blower while I am gone but it will be a while after I get back to actually get the blower. What are some advantages/disadvantages of running a lower compression engine built for a blower without a blower?
Or Give Me DEATH Last edited by phanatic32212; 09-16-2006 at 12:00 PM. |
09-16-2006, 11:58 AM | #7 |
ampsyco, where in florida are you?
Or Give Me DEATH |
