Old 09-10-2006, 12:24 PM   #1
LeftEar55
Removing the ignition switch assembly from a 71?
Well, the cab is completely stripped down, except for the ignition switch assembly. It'll turn to the left, as in inscrewing it, but after a couple of full turns, it stops? Does anyone know how to get this thing out of the dash? If not, I'm gonna try to sawzall it out
LeftEar55 is offline   Reply With Quote
Old 09-10-2006, 12:29 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Removing the ignition switch assembly from a 71?
You have to remove the switch tumbler before the bezel will come off. Turn the switch to acc. There's a small hole in the tumbler face. Push in to release with a paper clip, 1/16" pin punch, drill bit, etc. Then you can turn the key to the left and the tumbler comes out.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-10-2006, 04:20 PM   #3
c-1072
if you dont have the key i used a screw driver and a hammer . unscrew it as far as you can and wamo it worked for me .
c-1072 is offline   Reply With Quote
Old 09-14-2006, 08:39 PM   #4
LeftEar55
Thanks! This method worked nicely
