Old 09-10-2006, 04:13 PM   #1
dougs69c10
dougs69c10's Avatar
needle in a hay stack???
Finding a factory gas pedal assembly that still has the pedal on it? Everyone I look at for my 69 all have the pedal broken off.
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 09-10-2006, 05:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: needle in a hay stack???
it's a seperate piece, it snaps onto the floor.
Old 09-10-2006, 05:50 PM   #3
dougs69c10
dougs69c10's Avatar
where, b/c theres nothing on the floor where something/anythng would mount to
Old 09-10-2006, 05:59 PM   #4
1969C/10
Unskilled Labor
1969C/10's Avatar
There should be two little pieces of metal that stick up from the floor board and the pedal snaps into place on them. They should be right under where the pedal assembly ends.
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 09-10-2006, 07:10 PM   #5
jimmydean
jimmydean's Avatar
It's 2 pins that the pedal never stays on. My pedal is under the seat somewhere because I got sick of puting it back on all the time.
jimmydean is offline   Reply With Quote
Old 09-10-2006, 09:15 PM   #6
Longhorn Man
The CST style rubber pedal is real bad about popping off, the plastic base model style is OK.
If your truck is a bit of a beater, you can drive screws through the flap on the bottom (base plastic style) and into the floor. it'll never fall off like this.
The studs should be to round balls, kind alooks like zerk (grease) fittings.
