Hi, my lower door hinge bolt holes in the lower A pillar have stripped out. Has this happened to you? How do you fix it. It needs to be a quick repair!Thanks.
![]() Join Date: Mar 2004
Re: Door Hinge Bolt Holes Stripped!
retap with a slightly larger bolt size would be my first thought. metric prehaps?
I am a Referee of life.
You could also use a heli-coil.They are a device that looks almost like a spring.The ho;e ps drilled to a larger size then the heli-coil is screwed in with loctite on it.There is a small wire across the bottom of the heli-coil called a tang.After the heli-coil is screwed in the tang is broken off and the bolt will then thread into the hole like normal.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
roj2323, I went and tried to retap the whole first and figured if that didn't work I would go to a different size. So I went and tryed to run a 3/8- fine thread tap thru it. The tabe felt like it was rethreading wich I thought great. Until I backed the tap out. The hole had removed the groves off the tapp! So I said fine. I went and grabbed a 3/8-16 bolt and stuck it in the hole. It was a little tight at first but with a little persuasian I got that to thread in the hole. Did the same thing in the other holes and it worked.
Fine threaded bolts have more surface area for friction holding. This way they don't tend to back out. That's why fine threads are used on flywheel, damper, rods, etc.
#6 | |
![]() Join Date: Jan 2004
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
Roger the two above posts.
Fine pitch threads are actually stronger than course pitch threads also due to the surface area. |
