Old 09-11-2006, 11:35 AM   #1
75sierraclassic
75sierraclassic's Avatar
Window Lift Removal Tool
Does anyone know where you can buy the tool that removes the clip holding the window lever on so you can take your door panel off? I've found them on the net, but wanted a local store. Sears, Harbor Freight, etc.
How do you guys get the clip off? Do you use the tool or have you rigged something up?
75sierraclassic is offline   Reply With Quote
Old 09-11-2006, 12:01 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Window Lift Removal Tool
well last time i had an automoblie with manual windows(wish my truck did ) i used a toool that looked like a small fork. I think i got it from sears. it was great for removing plastic clips too. BTW NICE gmc I wish my 84 was a gmc ....
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 09-11-2006, 12:13 PM   #3
Jonboy
Slots go on anything!
You should be able to find them at a local auto parts store for under $10.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-11-2006, 12:27 PM   #4
us111
i just use a screwdriver,carefull you don't send the clip flying...
us111 is offline   Reply With Quote
Old 09-11-2006, 12:31 PM   #5
wedgemon
wedgemon's Avatar
I took the cheapest, pot metal forged, flat blade screwdriver I had. Tossed about 1/8 inch of it into the vise and bent it about 45º. Works great. Cost nothing and gets some of those hard to reach itchy spots, too.
But, watch for flying clips!!!
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 09-11-2006, 01:08 PM   #6
mhicks
mhicks's Avatar
All of the auto supply stores have them in the HELP section.
mhicks is offline   Reply With Quote
Old 09-11-2006, 02:34 PM   #7
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I use the T-shirt I'm wearing... Pops 'em right out.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 09-11-2006, 10:06 PM   #8
84slopwaggin
84slopwaggin's Avatar
I too found mine in the HELP section at Pep Boys. I can't remember the cost, though. I've use it many times. Last weekend, in fact.
84slopwaggin is offline   Reply With Quote
Old 09-12-2006, 12:02 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I have an old choke cable knob with a short piece of the hard wire on it that has been bent to a short hook, it works quite well fo hooking things like this. I also have a tool that is made to slide across the handle and push the spring off of the shft. Bought it at the local auto parts store, from their help tower display.
piecesparts is offline   Reply With Quote
Old 09-12-2006, 01:59 PM   #10
75sierraclassic
Hey thanks for the tips guys. I think I am going to have to try the shirt trick. If that doesn't work I found that Advance Auto Parts carries them.
Old 09-14-2006, 10:47 PM   #11
jimfulco
I bent a chunk of coathanger into as sharp an angle as I could, then cut off most of one side so the thing is just a sharp hook on the end of an 8" wire. Gently pry the door panel back with a screwdriver, hook the back of the clip, and pull. And, as always, watch out for flying clips.
jimfulco is offline   Reply With Quote
