Old 09-11-2006, 04:10 PM   #1
alpar80
drum brake removal
Im having a hell of a time trying to remove the rear drums off my 68? Is there any way to do this tried to hit them with a sledge, didnt try heat yet, will propane torch work? Any other ideas, pullers ect....
alpar80 is offline   Reply With Quote
Old 09-11-2006, 04:19 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: drum brake removal
If the pads have worn into the drums, they can prevent removal. Have you tried the ebrake adjustment pin. Adjusting them in will pull the pads in and may release the drum.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 09-11-2006, 04:19 PM   #3
northerngmc
northerngmc's Avatar
Stupid question but did you back off the adjuster?
Soak around the lug studs with penatrating oil.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-11-2006, 05:00 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I was in this same predicament with my '67 when I first bought it. The pads were down to the rivets and they had worn grooves into the drum. I just kept at it with a hammer, and prybar, knowing I was replacing everything anyway. I finally got it to break free, ended up replacing the drums (about $40), pads (15 or so) and a new spring set with all the hardware ($20) and now she's good as new.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-11-2006, 07:21 PM   #5
qksilver
you can also grind/drill etc the heads on the hold downs on the backing plate. That way the shoes and hardware will collapse and the drum will come right off.
qksilver is offline   Reply With Quote
Old 09-11-2006, 07:44 PM   #6
jhow66
jhow66's Avatar
It is probably stuck where the drum fits over axle hub. Soak with WD40 or the like and then hit on axle hub to jar it loose.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
