Old 09-11-2006, 04:18 PM   #1
northerngmc
northerngmc's Avatar
Locked rear wheel
I have a 72 GMC parts truck with no engine, trans or driveshaft. I tried to move it the other day by towing it and the right rear wheel is skidding.
The truck has been parked for a year or two in my yard, but I did tow it how and had no problems.
I imagine the brakes have seized.
Any suggestions to a quick fix to make it towable across my yard?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-11-2006, 04:25 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: Locked rear wheel
Remove the wheel and hit the drum with a hammer. That should break the shoes free from the drum.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 09-11-2006, 04:58 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
a BIG hammer. I'd spray some sort of penentrating lube in there as well.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-11-2006, 05:39 PM   #4
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
When I first tried to move my truck out of the weeds after 12 years, one wheel was frozen. When we hooked up to the rear to drag it back out of the road, it broke free quickly.
Don't know if that might be possible for you
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 09-11-2006, 06:28 PM   #5
northerngmc
I drug it with my tractor about 75 feet before even noticing! It didn't break free.
Maybe I should try dragging it backwards?
Blaine
Old 09-11-2006, 06:35 PM   #6
71SWBChevy
Post Whore
71SWBChevy's Avatar
if you are dragging it on a surface without alot of grip it probably won't break free, if you want to try breaking it free by dragging it you need some asphalt or concrete to drag it on.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 09-11-2006, 07:28 PM   #7
cdowns
cdowns's Avatar
big hammer idea is goodthey seem to break free better in reverse
Old 09-11-2006, 09:10 PM   #8
northerngmc
I drug it across the lawn and then up the paved driveway without it breaking loose. On thing is without an engine, trans, hood and a few other parts this truck is getting lighter.
It's raining tonight, so maybe another night this week I will try dragging it backwards.
Thanks for the ideas.
Blaine
Old 10-12-2006, 06:27 PM   #9
northerngmc
I hooked the tractor onto the truck this past weekend and pulled it backwards and the wheel turned. But when I hooked onto the front and moved the truck the right rear tire drug again??
Could I have a brake shoe come off?
The truck is now parked for the winter.
Blaine
Old 10-13-2006, 05:40 PM   #10
Huck
Huck's Avatar
If a brake shoe spring is off, you may drag it one way but perhaps not the other. Have seen that many times at boat ramps---kind of funny when the guy launches his boat but can't get the truck back out of the water!!hehehehe
Huck is offline   Reply With Quote
