09-11-2006, 04:58 PM | #1 |
1969 full floating axle
I reasently bought a 69 custom camper with 396, turbo 400, ac, tilt and hd springs, I am not familliar with these rear ends. had to trailer it home cause left axle was stickin out a few inches. when I got home I jacked it up on the trailer, romoved the wheel and drum, and was able to reinstall the axle, with some gentle taps of a mallot. Can anyone tell me what the proper fix is. truck will drive now but for how long?
09-11-2006, 06:52 PM | #2 |
Running on empty
Re: 1969 full floating axle
click on this link below, it will show how one these rear ends is dis-assembeled and re-assembled
http://www.lighthouse57.com/brakes.htm
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
09-11-2006, 10:00 PM | #3 |
Thanks Tim. From what I gathered from the link you sent, the lock nuts or tab washer must have come loose or broke. I hope the threads are not striped. I'll pull it apart in the morning. Thanks again. Mike
BTW My other truck is a 70 chevy longhorn,350/400,a/c,pb,ps.and all original with 94000 miles. |
09-13-2006, 02:18 PM | #4 |
Tore it apart yesterday, quite simple really, the lock washer or spindle washer as they call it, had broken it's locking tab so the nuts backed off. The threads got a little goobered up but I was able to gat them back in shape with a v shaped file and then run the nuts back an forth. I relaced the seal, bearings, nuts and lock washer and it went back together like new.
Thanks Tim for your help |
