Old 09-11-2006, 06:28 PM   #1
ChadMorris
Newbie truck Rebuilder!
Question Engine swap into my 64
Ok, I got a deal on an 350 tpi that included the 700R4 tranny that I couldn't pass up....
Can anyone help me out on what engine mounts to use in my 64...
Has anyone ever used the engine mount crossmember that Jegs and summit have?
Not really sure which way to go, the only V8 mounts I have have only 1 center hole, and the engine has a newer style engine mount .....
Any help would be great!!!
And any other info on installing the engine would be great...
I have spent the last week really reading up on the engine and the TPI system......
Chad
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 09-11-2006, 10:56 PM   #2
leftcoast66
leftcoast66's Avatar
Re: Engine swap into my 64
sounds like it's gonna be awesome once it's in. I havne't done one yet, but would suggest just calling summit and talking to one of their reps. I usually end up calling them and they usually know what to do, even if it's not from them. Or I'd suggest if you have a local parts house you go to, not like napa, but a local small one where the people are car guys, go and ask them, sometimes they know.
leftcoast66 is offline   Reply With Quote
Old 09-12-2006, 05:30 PM   #3
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
let me know what you find as I will be converting over from the old V6 in spring
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 09-13-2006, 07:22 AM   #4
ChadMorris
Yep, i am still looking for the right way to mount this....I will be calling Summit today to ask some questions about the mounting brackets they have....
I will probably also call the guys at the SECO shop or go buy, I bug them at least every other week on stuff....haha
Any other suggestions any one else has, speak up...!!
Old 09-13-2006, 08:42 AM   #5
60-66 Nut
Professional Beer Tester
Chad, there are several ways to mount the engine. I don't know what V8 mounts you have, but when you say "one hole" I guess you mean the 63-66 strait six and V8 brackets. These should bolt to the engine with the correct rubber mount, but there could be a problem with exaust manifold clearance depending on which ones you use. The 73-87 V8 brackets can be bolted to your frame, but they may pick the engine up a little in the front. I've never used any of the aftermarket mounting setups, but I'm sure there's something that will work. As for the transmission mount, a crossmember from a 63-72 truck with an automatic, or most any 73-87 crossmember can be used by simply drilling the holes in your frame where you need them. The only problem you might run into would be if your truck has the crossmember for the emergency brake, it might be in the way. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
