Old 08-12-2002, 08:02 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Question what gears were standard in 71'?
What were the standard gears in a 71' with a 12 bolt rear?. They feel like 3:07. Also I tried to rotate the wheel and count the rev's on the driveshaft but only turned 1.5 times.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-12-2002, 08:44 AM   #2
RodC
RodC's Avatar
Should be 3.73 Should be an option listed in the glove box if it is other than 3.73
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 08-12-2002, 08:44 AM   #3
Blazer1970
Blazer1970's Avatar
3.07 for trucks with 350s. 3.73 for 6 cylinders and 307s.
Blazer1970 is offline   Reply With Quote
Old 08-12-2002, 08:47 AM   #4
JimKshortstep4x4
Smile
The automatic transmission equipped V8 trucks had 3:07 gears in them as standard equipment.
Jim
Old 08-12-2002, 04:33 PM   #5
Rod
3.07 gears with a v8 if 2wd truck.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-12-2002, 05:36 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Pop the cover off and count the teeth.
How long has that oil been in there? 10...20...maybe 30 years?
Old 08-12-2002, 08:32 PM   #7
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Re: what gears were standard in 71'?
With an open rear with one wheel jackedup you have to multiply by 2.
1.5 x2 =3.00
real close to a 3.07
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
