Old 09-12-2006, 08:45 PM   #1
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Replacing fuel pump in a V-6?
As the title says, is it the same changing the fuel pump in my V-6 as in a small block?
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 09-12-2006, 09:02 PM   #2
TP from Cntl PA
TP from Cntl PA's Avatar
Re: Replacing fuel pump in a V-6?
Old girl sick? I was thinking about your truck the other day...............The K is almost done and I'll need another project for next year
Can't help with the fuel pump, haven't had an issue with mine(YET).
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 09-12-2006, 09:33 PM   #3
chevy_fatman
Where's my beer?
Yeah, went to start it the other morning to go to work and nothing, got rained on enough so I took the minivan instead fuel pump was acting up for a while but was hoping it'd last longer.
Thankfully I didn't sell it when I posted it for sale, I've used enough to not let it go now!
Anybody?
Paul
Old 09-12-2006, 09:51 PM   #4
JAKES 68GMC
Aluminum slot wheels rule...
Just pull the bolts out, take out the old one, and bolt the new one in. It's as simple as simple can get.
JAKES 68GMC is offline   Reply With Quote
Old 09-13-2006, 04:32 AM   #5
Bob B.
It's actually easier to do the fuel pump on a GMC V-6 than a small block Chevy. It's mounted higher, and you don't have that push rod to deal with.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 09-13-2006, 09:50 AM   #6
TP from Cntl PA
I thought they had a tang on them...............
Old 09-13-2006, 03:08 PM   #7
Bob B.
Yes, a long lever that rides on an eccentric on the front of the cam sprocket.
Old 09-13-2006, 07:00 PM   #8
chevy_fatman
Where's my beer?
Thanks Jake and Bob, I looked closer at the truck after work and the pump is indeed mounted higher, it should be a snap replacing.
Paul
Old 09-13-2006, 08:52 PM   #9
JAKES 68GMC
Stubby wrenches may help you out when unbolting it. Just a thought.
Old 09-13-2006, 09:01 PM   #10
chevy_fatman
Where's my beer?
Thanks.
Paul
