Old 09-12-2006, 09:26 PM   #1
Dadsredwagon
Dadsredwagon's Avatar
blinker/lights issue
Well finally got some time away from work and started to work the blinker issue i'm having, When I turn on the head lights the front parking lights go off??? but when I put the parking lights on, the right signal will not blink, still have brake lights and rear light at all times.
Any ideas?
trying to get the basic taken acare of so I can get it to pass state inspection.
thx,
todd
Dadsredwagon is offline   Reply With Quote
Old 09-12-2006, 10:04 PM   #2
iride
Re: blinker/lights issue
Hi
It sounds like there is a grounding problem take some jumper cables and hook on the ground on the battery and hook to the grill or headlight housing and see if it helps when you turn your headlights on
good luck!!
iride is offline   Reply With Quote
Old 09-12-2006, 10:14 PM   #3
jasonrmorrow
If your wiring is factory the park lights are wired to shut off when you turn the headlights on, there is a quick fix for it if you want them to stay on, jumper the park light wire to the taillight wire, purple to brown right at the switch.... I THINK !! Don't quote me on it, get a wiring diagram and find out for sure, or go to Jolly's GMC site he has the step by step how to do it.
As for the signal not working when the park lights are on...i had a bunch of issues that traced back to a dirty signal switch in the column, check your wiring at the column connector... I had to disassemble my column and just clean the switch contacts and everything worked great...saved me a good chunk of cash too.
There are two wires running to each park light, one for park lights and one for signal...the housing itself is the ground for the bulb.
The park circuit is quite simple and short so just start at the connector for the signal switch, then the firewall connector and finally probe the wires right at the light, shouldn't take long to find your problem... good luck.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
