Old 08-12-2002, 10:50 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Alt. Problems!!!Not charging...Battery dying...
Hey boys and girls...
My alternator seems to be a little fudged.....it works, keeps the charge even when I pull the neg. battery terminal. but it doesn't seem to keep the battery charged after. the battery just goes weak after an hour of haveing my engine on, or just haveing the lights at night when i'm messing with them. And after about a week the battery only has enough to turn her over. My truck isn't drivable yet, could it be that I don't give the alt. a chance to work and to charge the battery???? Hmmmm....
Also, as soon as I turn her on, I never notice how dim the cab light is until I shes all warmed up and I give her more gas....then all of a sudden the light just gets real bright, and stays like that until I turn the egine off. If I let it sit...the light is dim again. Hmmmm ANY help would do guys.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 08-12-2002, 10:58 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Cool
Sounds like it could be a bad ground somewhere. On top of the core support passenger side, remove the ring terminal and bolt and sand down to bare metal for brighter headlights. Also have your battery and alternator tested. I had 3 bad rebuilt alternators before I got a good one. Also my NEW battery had a bad cell in it. Fortunately the replacement alternators and battrey were covered under warranty. You could also be right about not letting it charge long enough. Good luck!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-12-2002, 11:15 AM   #3
SWINGSAX68
SWINGSAX68's Avatar
Lightbulb Thanks!!
I'll try that again.....seemed to work better the first time I did the 'scuffing' but I didn't do a great job of cleaning the ground. I know the alt wires have a ground....lets see there are four wires....black-blue-white-red....the black is ground from something so I grounded it to the wheel well...maybe I'm getting un-needed ground. cause every time I see a truck with my alt set up the black wire is disconnected...just hanging loose.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 08-12-2002, 03:28 PM   #4
Gordo
Smile
Can you get your hands on a volt meter?, (Didgital would be better) if so, attach pos & neg leads from meter to bat posts with truck off and take a reading, you need the batt fully charged to get a accurate alt reading and that would be in the 12.6 Volt range. If it's less than that, recharge batt first. Now that the batt is fully charged, with meter connected, start truck and take a reading, your goal is 13.8 to 14.2 volts running, if it's less you have a charging problem, now to determine what's at fault, the alt or reg. Keep in mine this is for TESTING PURPOSES ONLY! With truck shut down, unplug the reg and use a jumper wire to jump accross the bat terminal and the field terminal (should be marked F & B) of the plug end leaving regulator bypassed, now start truck up, take a reading, voltage should increase to 16-17 volts, shut down truck, alt is good and reg is bad if it read that voltage, if it didn't read that voltage the alt is bad. Hope this helps.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 08-12-2002, 05:47 PM   #5
chevyman 68 C/10
chevyman 68 C/10's Avatar
Could be as simple as neddeing to clean the bat. connections. The alt can be putting out but not able to get into the bat. to charge it up.
A internal regulator charging system seams to charge more at low speeds and is more depedable. It is a good mod. to consider making to these trucks.
GOOD LUCK!
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
