Old 09-13-2006, 01:48 PM   #1
truckdude239
truckdude239's Avatar
weird problem
okay when i turn my headlights on my left turn singal will not flash. with them off everything works perfect. i replaced the turn signal swicth about 3 months ago could a bad headlight switch cause this?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-13-2006, 02:56 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: weird problem
Mine does something similar. Everything works fine, but when you turn the lights on to the "park light" my left turn signal light comes on and stays on. I think it's a ground issue with the dash. I have yet to fix mine, but the blinker will work, jut the dash part is messed up.. When I pull the headlights to "on" everything works ok.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-13-2006, 03:09 PM   #3
67chevy2wd
67chevy2wd's Avatar
Re: weird problem
Is your left turn signal lit up? My car did something like this, everything off it worked fine, when I turned my parklights of my right turn signal was on in the dash. When I turned my headlights on my right side was dim and the signal light was still on, I had a bad headlight ground and it was grounding through the signal light which caused it to turn on.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-13-2006, 03:33 PM   #4
Jesse72
Jesse72's Avatar
Re: weird problem
i have a problem where i turn on my lights and the dash loses everything, the gas gauge goes past empty. I beleive it is a ground issue
Jesse
72 4x4 Sold
59 GMC air ride ls swap
Jesse72 is offline   Reply With Quote
Old 09-13-2006, 04:40 PM   #5
underdog8704
NCStroker
underdog8704's Avatar
Re: weird problem
do you guys have any bulbs out in any lights. one of my running lights was out and my signal stayed lit up when the lights were on. once i replaced the bulb it was fine. check all your lights.
underdog8704 is offline   Reply With Quote
Old 09-13-2006, 04:58 PM   #6
centsless
sufficiently talented fool
centsless's Avatar
Re: weird problem
I have also seen this happen when a turn signal/park light bulb (1157) is installed wrong or the bulb socket is bad. Check the grounds very good. That is the most common cause.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 09-13-2006, 05:21 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: weird problem
truckdude and67 redneck, replace the tail light and front parking lights... all 4 1158 bulbs, or a 20 57 for brighter brakes/flashers, and see what happens.
The truck is designed to do this when a bulb goes bad. It senses the lack of continuity to the ground, ahnd lights up the indicator. If new bulbs doesn't fix it, then check the grounds (including the sockets) out front and in back.
Jesse72, you do in fact have a very weak ground on your inst panel.
Old 09-13-2006, 05:49 PM   #8
truckdude239
Re: weird problem
1158? i have 1157s in the truck now 2057 are brighter i might get them i'll try that frist
i been having a problem with the rleft rear brake light not working bulb looks good park light works i took it apart and cleaned the ground and got park lights to work and the front stoped working i'll go get bulbs and try that
David fuller
2000 Tahoe 5.3l 378
Old 09-13-2006, 08:53 PM   #9
Longhorn Man
Re: weird problem
yeah... 1157 and 2057. If your normal chain type parts store doesn't have them, NAPA should. That's who stocks ours.
