Old 09-13-2006, 03:59 PM   #1
crosby
crosby's Avatar
87 V20 TBI headers? Anybody got headers on TBI?
Hi guys. I have an 87 350 TBI in my V20 4x4, with the air tubes and all that crap. I believe I need the O2 sensor to run the TBI correctly, and thus the stock manifolds. Nobody seems to make headers for this truck, and I really don't want to run the AIR tubes if I don't have to. Can I add an O2 bung to regular headers? Has anyone done this? Thanks guys!!
Crosby
1978 Chevrolet K10 stepside
NH
crosby is offline   Reply With Quote
Old 09-13-2006, 06:06 PM   #2
krazymonkeys24
Re: 87 V20 TBI headers? Anybody got headers on TBI?
You can go about that in 2 different ways. You can either add the bung on a set of headers or on the y-pipe, or you can use an O2 sensor bypass thing that i saw in jegs once. Hang on a sec and i will get the part number for ya. i have a catalog handy and will be easier to find there.
Eagles may soar, but weasels don't get sucked into jet engines.
krazymonkeys24 is offline   Reply With Quote
Old 09-13-2006, 06:20 PM   #3
krazymonkeys24
Apparently, those are for rear o2 sensors only, meaning after cat. There is one thing you could do to solve your problem, that I know of,but it would mean a slight rework in your y-pipe. The 82-92 f-body headers have that o2 bung and the tubes, but if you wanted to get rid of the tubes, they are easy enough to cut and weld. then some VHT paint to cover the bare metal. As far as the y-pipe, you may even be able to use the f-body y-pipe. I have never tried that, though, being that everything that I put headers on also gets true duals with no cats. I have always just let the check engine light stay on and let the computer run in open loop as far as o2 sensors are concerned. that's what most people do with 30's and 40's rat rods with factory EFI systems. I hope I have been moderately helpful.
Old 09-13-2006, 10:17 PM   #4
C&C Chevy
C&C Chevy's Avatar
Lookie here. These look like they bolt up to the stock y-pipe, so you shouldn't have to worry about the 02.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 09-13-2006, 11:09 PM   #5
krazymonkeys24
Hey, that works too.
Old 09-15-2006, 07:16 PM   #6
68Bowtie4x4
68Bowtie4x4's Avatar
I have a set of Doug Thorley Tri Y headers on my 87 K20 4x4 pickup. They have the O2 bung already in the header for the sensor too. I paid $350 for the headers.
Doug
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress.
68Bowtie4x4 is offline   Reply With Quote
Old 09-15-2006, 08:03 PM   #7
danny7139
shorties are a good option if you dont want to have to make mods or change anything. they can have 02 senors bolt to y-pipe and can have A.I.R. installed on them
danny7139 is offline   Reply With Quote
Old 09-15-2006, 10:36 PM   #8
crosby
crosby's Avatar
Lots of good options, thanks guys. My dad told me the O2 sensor wasn't a huge deal, but I do want it to be right if at all possible.
Crosby
NH
Old 09-16-2006, 12:06 AM   #9
Russell
Professional Grade
Russell's Avatar
O2 sensor is a HUGE deal, don't delete it, or put some device in to fool the ECM. Unless you have a perfect chip (which the stock GM chips certainly are not) you are gonna get some really sucky performance from your truck without.
You can buy an 02 sensor bung for a couple of bucks from any exhaust shop, or parts house. Simply get it welded onto the collector of your header, and go nuts!
Keep in mind that even with shorty headers, the 02 sensor will be quite a ways away from the exhaust ports, and that the exhaust will have cooled significantly. You may possibly need to switch to a heated 02 sensor to make sure you get into closed loop quickly, and stay there.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
