Old 09-13-2006, 04:51 PM   #1
SUBURBULANCE
71 k5 blazer
I have a gas guage that has not worked since I bought the vehicle. when looking at the sending unit i notice that there is just the main wire (1) coming out of the sending unit going back to the fuse box, no ground. my 70 suburban ambulanc has that same wire and then an additional wire that grounds to the bumper. Am I missing a wire or is the sending unit on the 71 k5 ground inside the tank?
SUBURBULANCE is offline   Reply With Quote
Old 09-13-2006, 04:54 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 71 k5 blazer
1st - from West TN
2nd - If memory serves on my Blazer, seperate ground wire
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-13-2006, 05:28 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 71 k5 blazer
Don't know about the sending unit wire, but welcome from the Pacific NW. Post some pictures of your blazer when you get a chance.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-13-2006, 05:36 PM   #4
vtblazer
vtblazer's Avatar
Re: 71 k5 blazer
Nope, should be outside.
Welcome from VT.
vtblazer is offline   Reply With Quote
Old 09-14-2006, 05:29 PM   #5
SUBURBULANCE
Re: 71 k5 blazer
Pretty New To The Board, Thanks For The Welcome. I Am Not Sure How To Post Pics Yet But I Will Try To Figure It Out. I Have A 71 K5 Blazer, 70 Suburban Ambulance, 56 Bel Air Wagon, And An 03 Silverado
Old 09-15-2006, 04:07 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 71 k5 blazer
Frame is the negative side. The Tan wire is your fuel gauge sender feed. If you unplug it and the gas gauge pegs to the right, it's not the gauge. Most likely the sender, inside the tank, or the brass float ball on the sender arm.
You will have to drop the tank to get to the sender and/or ball. On my '71 Jimmy, I will have to un-rig a tow hitch crossmember, and unbolt a bulletproof shield around the fuel tank. Since I hav'nt had the time to do all this, I keep a mileage log and make sure I don't go more than 200 miles before filling up again. [20 gallon tank @ 10 MPG]. Good luck. And welcome to the board.
Old 09-15-2006, 09:33 AM   #7
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: 71 k5 blazer
look in the FAQ part of the board theres all kinda good info in there
http://67-72chevytrucks.com/vboard/f...splay.php?f=28
heres one on posting pics http://67-72chevytrucks.com/vboard/s...d.php?t=209103
tnblazerk5 is offline   Reply With Quote
Old 09-16-2006, 08:53 AM   #8
lawricker
lawricker's Avatar
Re: 71 k5 blazer
Welcome to the board. I agree with Sunshine, probably in the tank. Only a single wire.
Retired and working my tail off..
lawricker is offline   Reply With Quote
