Old 09-13-2006, 10:21 PM   #1
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Question Disk brake conversion
Can any one tell me where I could find a step by step with pic's of a front disk brake conversion on a 70 c10?
thanks
Ralph
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 09-13-2006, 10:41 PM   #2
jimmydean
jimmydean's Avatar
Re: Disk brake conversion
This was a write up in Truckin' and incluges drop spindle install (like the kit I have on order).
http://www.classicperform.com/discdrop.htm
jimmydean is offline   Reply With Quote
Old 09-13-2006, 10:46 PM   #3
Geezer
Geezer's Avatar
I don’t have a step by step, but I can probably find a few of the 88 suburban complete crossmember swap.
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
Old 09-13-2006, 11:30 PM   #4
krue
Designated A-hole!
krue's Avatar
What you want to do? Entire crossmember swap?, kit?, spindle only swap?
The easiest/cheapest is probably going to be the crossmember out of a 73 up.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-14-2006, 09:05 AM   #5
oj70chevy
250 V-6 Club
oj70chevy's Avatar
I’m not sure. I am not a heavy duty mechanic but should be capable of doing this. I guess I am looking for the easiest way to do it. I would like to keep the stock look of 6 lug and height and was also going to start looking for a kit that would supply everything I would need to get this done. Also any suggestions on where I could get a full kit would be great.
Old 09-14-2006, 09:39 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Here is another article with the kit I will be using. I got my kit from GMCPauls.
http://www.classictrucks.com/tech/05...rakes_install/
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-14-2006, 09:47 AM   #7
boraxman
Keepin an eye out
boraxman's Avatar
I would do the full crossmember or a kit for sure. I pieced mine together w/ 71-2 spindles, discs, calipers, ball joints, tie rod adapters, etc. etc. etc. Junk yard here, auto parts there....
Major PITA.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 09-15-2006, 07:01 PM   #8
Geezer
Geezer's Avatar
I had the 88 suburban laying around with a blown rear end. I used a bunch of parts from it including the engine. With the price of gas, I've seen several late 80's, early 90's subs around in the $1000 range. I even used the brake lines and proportioning valve, steering box and hoses… Saved me a bunch of money on small parts like bolts, screws, and some wires and on and on…
Old 09-15-2006, 11:52 PM   #9
qksilver
everything from a later model will bolt to your orginal crossmember, I have done the swaps both ways and other than being able to drop the oil pan with clearance with the later model crossmember, it is a pain. The only real advice i can offer is when you do the swap, with or with out the crossmember try to use the complete front end, spindles, a arms, P/S box etc for convienence sake, that way you know what year all the parts are and no swapping problems with different tie rod ends etc.
Plus not sure when it started but i know that from 86 up they had wider front rotors like the ones offered on the heavy half tons from the 70's and using a 5 lug rear from a 71 I also used the wider rear brakes, backing plates out from the 86
qksilver is offline   Reply With Quote
Old 09-16-2006, 02:12 AM   #10
jimmydean
jimmydean's Avatar
The kit I got form GMC Pauls uses the stock '69 ball joints and tie rods. So keeping parts straight is easier. I like the idea of the later model stuff, but my drick is more of a cruiser than a performance machine.
I have a hard enough time now getting what I need at the parts store without multiple trips or brining the old part with me.
Old 09-16-2006, 03:20 AM   #11
qksilver
The benifit other than thicker rotors with the later model stuff 73-up is that the price of parts is cheaper and the rubber control arm bushings that give you a slightly better ride
Old 09-16-2006, 07:38 AM   #12
70GMCer
70GMCer's Avatar
did he say "but my dick is more of a cruiser than a performance machine" ?
oh sorry...... "drick"
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-16-2006, 12:15 PM   #13
jamon8
jamon8's Avatar
I put a crossmember from an 84 c-10 with a 6.2 diesel
that stuff is heavy duty to the max and the tie rod ends of my 69 which were new fit right in.
my truck should be pretty stought in the front with all poly bushing
hard core in the back with poly, 3/4 ton hd springs and the helper leafs.
I cant wait to put in a locker and put big boats out of the water with a 1/2 ton 69
jamon8 is offline   Reply With Quote
