Old 09-13-2006, 11:34 PM   #1
krazymonkeys24
Steering column problems
maybe someone can give me a how to and some info. I have a 77 Silverado LWB with a roller 350 and TH400. My question is about the column. It has the usual tilt wheel and while it steers ok, the wheel now flops around like a bobble head. The tilt works fine and is good and solid. It's right below where the wheel attaches to the column. It moves far enough to see almost everything, the wiring, turn signal cancel cam, everything. First off, has anyone had this problem and know how to go about repairing it and second off, where to get the parts? I have never torn into one of these columns before. Done quite a few f-bodies, but never even had this type of problem with them. It was always the tilt mechanisms, not where the wheel mounts to the column. I have tried to see exactly what is loos, but can't quite figure it out. I'd go ahead and tear into it, but thought I would ask before I did something that may make it worse. BTW, I'll post some pics in a few days.
Eagles may soar, but weasels don't get sucked into jet engines.
krazymonkeys24 is offline   Reply With Quote
Old 09-13-2006, 11:58 PM   #2
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: Steering column problems
there are a couple of plastic bearing that work loose or wear out, and you do have to do a full tear down of the head stock but not pull it from the truck.
i run striaght columbs for this exact reason.
trkklr77 is offline   Reply With Quote
Old 09-14-2006, 12:01 AM   #3
krazymonkeys24
Where can i get them and how much time do I need to set aside to finish it?
Old 09-14-2006, 01:01 AM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Here's a link to a link (http://67-72chevytrucks.com/vboard/s...d.php?t=194740) that may be the cause of your problems.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-15-2006, 07:30 AM   #5
krazymonkeys24
Thx alot for the links. I will try that Sunday. Auto Fair is in town this weekend, so i will be indisposed tomorrow, lol. It's a huge swap meet/car show at Lowes Motor Speedway just outside of Charlotte. My 2 year old son and I are probably going to be there quite a while if I can get him to look at all the "cool cars" long enough lol.
