Active Member
Front Drop....add shims or delete shims????
If I were to add dropped coil springs on the front would the alignment shop have to add shims or delete shims on the upper control arm mount????
1971 SWB SOLD
Seņor Member
Re: Front Drop....add shims or delete shims????
Delete.
Neither. Shims are for setting caster and camber settings.
Mike
Mike Redpath |
Active Member
Musclerodz,
I realize shims are for setting castor and camber. My question is: when installing lowering springs does the camber become more negative or more positive....i.e will the top of the tire lean in more or lean out more?? Would I have to add more shims or delete shims to correct for the lowered spring? There is so much conflicting data out there, just trying to find the correct answer. Here is some info I found on the web describing camber: Camber - when you view the car from straight ahead or behind, the amount that the wheels "lean" towards each other. Negative camber looks like this: / \ Positive camber looks like this: \ / Thanks for everybody's help, Shane
1971 SWB SOLD
67-72 parts finder
you drop a vehicle and its gonna have negative camber in the front
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
Seņor Member
So when he reduces the ride height by installing a lowered spring, the control arms are going to pitch UP in their arc, reducing camber angle.
Hollister Road Co.
Outlandish Trends - FL
Precisely why he is asking the question. "Neither" is not the answer.
-Bret 67 short-fleet sold! |
If you are going to get it aligned after, and you should, then just slap yer springs in and let the alignment shop do all the work.
I have dropped spindles and bags, before that i had stock spindles and 3" springs, there is only 3/4" of shims on my control arms, didnt have to touch it after getting it aligned at 3" springs and then at ride height with the bags. The first alignment was done by someone else, but the 2 since then have been done by me, havent touched the control arms yet. Camber/caster all in spec and drives great.
1964 - LWB 350 TPI Fuel Injection On airbags |
if u do spindles then u dont change anything out because they were made to correct the camber but if ur goin to run just springs then ur goin to have to add but like they said let a shop do it because ur truck is supposed to have some what camber from factory
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
#11 | |
I would also get it aligned even if it's just a spindle swap (it's cheaper than a new set of tires).
Hollister Road Co.
just as a note Moog sells a "Problem Solver" upper cross shaft that has addtional negitive camber built into it. I had to use them on mine.
#13 |
Active Member
Thanks everybody,
The reason I was asking is that I already have dropped spindles and am looking at 1.5 inch drop springs. Right now, the passenger side has a bunch of shims and no bolt left to add more (just had it aligned too!!). I guess I'm stuck with the ride height I have though. Shane
1971 SWB SOLD
#14 | |
Those 'offset' a-arm shafts will be the equivalent of adding shims. You could possibly get away w/removing a shim or 2 if you used the offset shafts. Visit the front end guy that you plan to have do the alignment & see what he says. FWIW.... On my 68 I have 2.5" drop spindles w/1 coil removed from the original springs (= 2~3" of drop) for a total of about 5~6" front drop. I still have room for more shims if they were required.
#15 | |
![]() Mike
Mike Redpath |
#16 |
So it is possible to get the wheels back to factory specs with drop springs.Now heres the question how much does it cost?
#17 |
depends on the frt end shops charge because once u lower it, its best to take it to a frt end shop and get it realigned because it doenst hurt because u can do the drop and end up killin a set of tires i learned the hard way on my 96 when i put spindles i ended up killin the inside of my 17s
#18 |
I just noticed the outsides of my tires are wearing funny. When I have the bags at about 3", I have positive camber. I have an appointment with a shop to get it adjusted, but I am waiting until I get my new cross shafts. Should be here this weekend.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#19 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 02-14-2007 at 06:30 PM. Reason: forgot sompin |
