Old 09-14-2006, 10:45 AM   #1
Boog
laying low
Boog's Avatar
brake lines
I have an 82 front suspension under my 69. I am down to running the brake lines. The flex lines from the 82 calipers run along the front of the upper control arm. Aren't the 69 hard lines supposed to run behind the crossmember? I want to avoid a cobbled up looking brake line setup. Any pics? Thanks.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-14-2006, 12:45 PM   #2
70GMCer
70GMCer's Avatar
Re: brake lines
Pics would be nice as I'm going to be putting an 84 suspension under my 70...
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 09-14-2006, 01:21 PM   #3
Jim_PA
Re: brake lines
In 71, the front hard lines started getting mounted to the front of the crossmember. You will probably have to run new lines, and a new bracket that will mount to the front of your 69 crossmember.
Jim_PA is offline   Reply With Quote
Old 09-14-2006, 08:02 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: brake lines
i just finished mine and i ran the p-side and rear hard lines up to and around the front crosss member. like how the 72-87 stuff would normally look. i also ran the 73+ prop valve so i ran 3 lines down to the frame, i really dont like or trust the t fitting in the line.
trkklr77 is offline   Reply With Quote
