09-14-2006, 01:57 PM | #1 |
c-notch
Are the bolt in c notches any good? I put the rear flip kit from djm on my 05 silverado and need to notch the frame. I figured this is the best place to find out. Thanks
09-14-2006, 02:20 PM | #2 |
Re: c-notch
I bought the bolt in kit, but I will weld it in place. I like the extra coverage the bolt in version gives you, but I don't trust that it won't develop play and cause a weak point later on.
09-14-2006, 10:27 PM | #3 |
Re: c-notch
We put a bolt in notch in my buddy's '98 extended cab after we did a 5/7 and he never had any issues.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
09-15-2006, 01:27 AM | #4 |
Re: c-notch
thanks guys
09-15-2006, 01:52 AM | #5 |
67-72 parts finder
Re: c-notch
i agree with jimmydean i'd bolt it AND weld it if it was on my truck just for the extra security
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
09-15-2006, 07:41 AM | #6 |
Re: c-notch
I have done bolt in's with out a problem but I do like to add a few welds on them if possible. If you do not weld then bolt it in and drive to a muffler shop and have them put down a few welds for you. They should not charge much and if you show up around quitting time with a 12pac they may not charge at all!
Kevin LFD Inc. |
09-15-2006, 02:22 PM | #7 |
Re: c-notch
I thought I recalled a pic from Kevin with a welded "bolt-in" notch. I could be wrong, but I got the idea from somewhere.
09-15-2006, 11:28 PM | #8 | |
Re: c-notch
09-16-2006, 11:43 AM | #9 |
Re: c-notch
I welded in a bolt on c notch
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
09-16-2006, 06:59 PM | #10 |
Re: c-notch
It would be stronger than the original frame section using this method.
That's what I did on my 68. I bolted it in while using it as a driver & then welded it like this once I began using it to pull my 18ft car hauler. I will admit, my welds don't look as good as these since I did it outside & the wind was killing me that day.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-16-2006 at 06:59 PM. |
09-17-2006, 06:33 PM | #11 |
Re: c-notch
Ah beer, the universal currency! I've gotten several hundred $$ of work done with $30 worth of beer.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
