Old 09-14-2006, 05:38 PM   #1
76bonanza
76bonanza's Avatar
vaccum advance question
I have an advance problem.
First I have a leak in the rear of my canister I can stick my finger back there and it sucks it up to a little hole in the rear. I am guessing that is not good?
I get no advance at idle if I hook it up to full vaccum I am guessing that is not good either.
So is my advance bad? I have an accell distrubuter can I just replace the advance and is it easy? Also If I drive it for a while like it is will it hurt the motor?
Thanks for all your help.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-14-2006, 06:25 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: vaccum advance question
a vacuum advance unit is about $12.00 only 2 screws hold it...very esy to change...buy new...
rage'nrat638 is offline   Reply With Quote
Old 09-14-2006, 06:35 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and plug off that vac port untill you can replace the unit.
Old 09-14-2006, 07:29 PM   #4
76bonanza
76bonanza's Avatar
Got it off no sweat going to get a new one. Should I replace the rotor also? I have an accell super coil cap and coil And looks like an MSD modual(yipee)
1968 c10
lowered 3" 4"
Old 09-14-2006, 08:24 PM   #5
Longhorn Man
If your cap and rotor looks old or questionable, replace it whiel you have it off. Puttin a bad part back on is kinda like taking a shower and putting on dirty underwear.
Old 09-14-2006, 09:08 PM   #6
76bonanza
76bonanza's Avatar
Ok good to go replaced it all better now thanks.
One more thing I am running full vacuum to my advance.
What is the exact process for setting idle mix when you are using manifold vacuum for advance(please no arguaing about which port is best.
1968 c10
lowered 3" 4"
