Old 09-15-2006, 12:32 AM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
sheared the bolts on the steering box off!
title say's it all. It's hanging on by one bolt at the moment. I can't get the drag link off the steering box. any suggestions?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 09-15-2006, 10:04 AM   #2
Burt4x4
Burt4x4's Avatar
Re: sheared the bolts on the steering box off!
Well hopefully your frame didn't crack?
Getting all apart is hard even with the bolts not sheared.
I can't type a fix but I can suggest what tools to use
BFhammer, torch, grinder, prybar, ratchet strap to hold the box, drill, hmmmm and a six pack
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-15-2006, 10:10 AM   #3
jhow66
jhow66's Avatar
Use a claw puller.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-15-2006, 01:50 PM   #4
RED72blazer
urban fourwheelin
yeah, I really hope my frame didn't crack.
Old 09-15-2006, 02:26 PM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
or a pitman arm puller or a pickel fork.
trkklr77 is offline   Reply With Quote
Old 09-15-2006, 03:10 PM   #6
nathan_454
same exact thing happened to my 71 K5... I sheered 3 of my four, and messed the fourth one up... I wasnt really wheeling either, I was turning around and one tire dropped into a small ditch, just enough to flex the suspension, and snap!
It didnt crack my frame though, hopefully you are as lucky.
nathan_454 is offline   Reply With Quote
Old 09-15-2006, 04:20 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by nathan_454 View Post
It didnt crack my frame though.
Thank God for that one, that would have sucked
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-16-2006, 08:00 AM   #8
Pull the drag-linkoff the steering arm.Once you have it off the vehicle you can get the pitman off much easier.
I just responded to a post where a guy was saying using washers to mount p/s on a`67 ain`t no problem,then I read this.
Old 09-16-2006, 03:34 PM   #9
classicchev
classicchev's Avatar
Obviously not Grade 8 bolts, make sure you replace them with grade 8 stuff.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 09-16-2006, 08:00 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Use a big hammer and wack it hard as if you were hitting it on. This will loosen it up a bit. then use a pickle fork and a hammer. I've got a pickle fork if you need to borrow one. Just come by.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-18-2006, 02:04 AM   #11
RED72blazer
urban fourwheelin
yeah I definatly need to get a pickle fork, But I have no car right now. I'll see if I can borrow one, so i can borrow a tool.
Old 09-19-2006, 03:24 AM   #12
RED72blazer
urban fourwheelin
Well, I got the box off today...I just needed a bigger hammer. Frame's not cracked...all is good
Old 09-20-2006, 01:49 AM   #13
71jimmy
71jimmy's Avatar
COOL!!!!!!!!!!!!!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
