Old 09-15-2006, 09:40 AM   #1
Joe67
67 is sold
stripped fuel filter mounting
Well, I stripped the opening for the fuel filter in my rochester carb
My carb number: 7028213 DY
Of course I stripped the carb end of the threads, not the nut...
I posted a WANTED ad in the new classified section.
Does anyone know what carb pieces are compatible with a 1968 Rochester quadrajet that was used on a 327 truck motor application?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-15-2006, 09:57 AM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: stripped fuel filter mounting
if you are running a inline fuel filter you can use epoxy to fix the carb , just put a little around the nut threads and cram it back in the carb just remember that you can not ever take it back off once you do that so dont put a filter in there
and when ya are putting the fuelline in to it use a 1inch wrench to hold it in place so that it dont bust the carb anyworse, i have did a few like that
tnblazerk5 is offline   Reply With Quote
Old 09-15-2006, 01:35 PM   #3
john
member #16
john's Avatar
You can buy oversize self tapping nuts that will cut new threads at most parts stores.
john is offline   Reply With Quote
Old 09-16-2006, 08:33 PM   #4
Joe67
67 is sold
Good Idea, I'll check into that. Thanks
Old 09-16-2006, 08:42 PM   #5
qksilver
In the help section at carquest they have an oversize fuel fitting that will cut new threads, just becareful to make sure no fillings/metal get into the carb
qksilver is offline   Reply With Quote
Old 09-19-2006, 03:15 PM   #6
Joe67
67 is sold
here is my carb number: 7028213 DY
