Old 09-15-2006, 11:17 AM   #1
49studebaker
49studebaker's Avatar
HEI with original Tachometer
Can anyone tell me? Will the stock tach in my 71 GMC work with a HEI Distributor? I saw somewhere in a catalog for factory replacement tachs that said "will not work with HEI"? Thanks
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 09-15-2006, 12:12 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: HEI with original Tachometer
I'd be interested to know that too. I just picked up a complete tach instrument cluster with a bunch of parts I bought a week or so ago & would like to put it in my '67/454/HEI rig.
LockDoc
Leon
Old 09-15-2006, 01:17 PM   #3
LockDoc
LockDoc's Avatar
Here is a thread I found on the subject.
http://67-72chevytrucks.com/vboard/s...highlight=tach
LockDoc
Leon
Old 09-15-2006, 01:54 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
should work like any after market tack, tach wire to the neg side of the hei snout. if you lock close it will say batt+ on the right for the hot wire and tach on the left for the signal wire.
trkklr77 is offline   Reply With Quote
Old 09-15-2006, 02:41 PM   #5
powell72
powell72's Avatar
I have a factory tach with HEI, no problems or any extra parts needed.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 09-15-2006, 03:13 PM   #6
junkyardjohn
junkyardjohn's Avatar
I'VE PUT AT LEAST A DOZEN FACTORY TACHs IN TRUCKS EQUIPTED WITH HEI.s WITHOUT ANY PROBLEM. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 09-15-2006, 04:30 PM   #7
msgross
msgross's Avatar
no problem with mine, original factory tach and Mallorey HEI distributor. I just put on a female connector and plugged it in....
msgross is offline   Reply With Quote
Old 09-15-2006, 04:42 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
plug and play.
Old 12-30-2006, 08:49 PM   #9
trkklr77
trkklr77's Avatar
back for the the dead,
i just got around to mine and had no issues, works fine.
Old 12-30-2006, 09:10 PM   #10
corn
Its just a way for the gauge companies to sell you a $100 adaptor that amounts to a wire with an HEI wire end. It will work fine, just hook it up...
corn is offline   Reply With Quote
Old 12-30-2006, 10:47 PM   #11
wolfthing2000
For what it's worth, I just picked up a NOS Sun tach from the late 50s and early 60s that originaly worked with a sending unit, like a magnetic switch that would open close kinda each rev of the engine off of firing intervals from the coil.
I had it rebuilt to work as a modern instrument without the sending unit and to withstand the MSD voltage. The big thing to watch out for is the higher voltage that the tech told me could fry the old school stuff. The older stuff was a lot more forgiving voltage wise than the newer high volt ignitions.
wolfthing2000 is offline   Reply With Quote
