09-15-2006, 04:49 PM | #1 |
Transmission massaging
Hi,
I would like to put a 700r4 transmission in a 1969 reg cab short bed truck. How much, if any, sheet metal/trans tunnel massaging will I need to do? Also, what are some of the trial and tribulations of putting this thing in? Thanks, David Last edited by djw32; 09-15-2006 at 04:55 PM. |
09-15-2006, 05:19 PM | #2 |
Re: Transmission massaging
My '71 came stock with a manual 3 speed trans, with a column shift (low hump cab). I've had both a TH400 and now a 700R4 in it. No modifications needed as far as the sheet metal was concerned. I did have acquire an auto trans crossmember, because with the 3 speed, the rear motor mounts attached to the bell housing...It was actually a relatively easy swap..
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
09-15-2006, 05:33 PM | #3 |
vfrdude,
Nice . Where can I find an auto trans crossmember? Is there a company having them made? Thanks, David |
09-15-2006, 05:37 PM | #4 |
If you subscribe to the board you can post a "Want to Buy" ad and someone here will have one for you.
09-15-2006, 05:45 PM | #5 |
I went to a wrecking yard and bought what I needed from an automatic truck. It's been so long, I almost forgot that the getting those rear mounts out was a real pain! They're riveted to the frame.....so, other than that is was relatively easy! Good idea by ChevyDude to post in the 'wnat to buy' section.
09-15-2006, 11:58 PM | #6 |
there are also aftermarket trans crossmembers that aren't that expensive, plus they look like it would be easier to run your exhaust tucked up. CCP carries them as well as a couple of the board vendors
09-16-2006, 12:05 AM | #7 |
I would like to thank everyone for the information
