Stepsides RULE
L.E.D. sidemarkers
Well, I know you can use L.E.D. taillights from recent-model Wranglers for us stepsides, and I think they make L.E.D. tails for fleetsides, maybe. I wanna know if anyone has ever homemade (or bought?) L.E.D. sidemarkers for our trucks. It doesn't sound hard in concept, fabricate/purchase a panel of L.E.D.s either the same size or a little smaller than the housing for the stock bulb, splice it in, and then change the resistor for flashers (if need be).
Think its feasable?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
Until Seventy Times Seven
Re: L.E.D. sidemarkers
Yes, it's very feasible.
You may have to experiment with the number and placement of the LEDs for the desired effect. But, it should be a straightforward mod, even if you have to adjust the intensity of the LED light output. I wouldn't believe a high power resistor is necessary for the flasher operation due to the relatively low sidemarker bulb wattage. But, if needed, you could instead go the route of an electronic flasher especially if you plan of installing other LEDs for tail/brake lights, etc. Use a good qualtity LED like Superflux, too. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 09-16-2006 at 04:01 PM. |
