Seasonal Poster
Cab Sound Deadening Help?
i was just wondering if anyone could recommend some ideas for what to use to quiet the inside of my truck down...its pretty loud when im going down the highway, i can barely hear me stereo sometimes, where talkin' tire noise and the like...any good products out there to use? and if so, how would you go about installing some of it? like in the doors or on the floor or....?
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
I used this stuff
http://www.gcp-grace.com/products/wa...ies/b3000.html Cost 55 dollars for 100 square feet. Similar to Dyromat. Put two layers in plus did the doors
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
Seasonal Poster
dude thats looks like it should work...thanks!
Keepin' It Stock
I just put RAAMmat in Maych. Haven't gotten to drive it yet to see what difference it makes but it gets good
reviews and is waaay cheaper than Dynomat
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
its all about the +6 inches
Something else you can do is spray some under coating under the cab, in the fender wells, and then unside the doors, and back in the cab dorners in between the cab and fuel tank. Then you put duct tape over all the holes in the door under the door panels...that helps quite a bit.
Before you put in any mat material spray the cheap bed liner material in the doors,floor, behind the tank,behind the fire wall and under the head liner if you have one. Another place if you are really serious put a coat under the bed. Make sure you don't stop up the drain holes in the bottom of the doors.(one in the front and one in the rear)
$50.00 Goes a long way to totaly quiet down the road noise and if you put in the mats you won't hear anything if your window seal are in good shape.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
You can buy dynamat at most stereo shops. Its real pricey but works amazingly well. One of the best things to do is make sure there arent any unwanted holes in the firewall or floor, leaking air makes alot more noise than youd think.
No, Its not a 454 |
