Old 09-16-2006, 02:24 AM   #1
rcbildr
rcbildr's Avatar
Question Need some electrical help.
I just finished replacing the automatic (700R4) with an SM-465 in my 85 Suburban. My question involves the neutral safety/reverse light switch that is on the steering column. There is only 2 wires going to the switch, a purple and a green one. I'm used to seeing the neutral safety switch with 4 wires. Does that switch complete the circuit by grounding to the frame? I think it does, but I want to double check first. Any help will be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
