Old 09-16-2006, 10:19 AM   #1
Ormly
Headlights not working
Hi Folks,
My 86 GMC has a problem with the headlights no longer working. It all started off as being intermittent. Can anyone point me in the right direction to a schematic before I start in on the trial error routine?
Thanks,
Orm
Ormly
Ormly is offline   Reply With Quote
Old 09-16-2006, 01:07 PM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: Headlights not working
A Helms shop manual will have the schematics for the wiring. They'll sometimes have discounts for some manuals that aren't reprints. In lieu of that, try Autozone's online wiring diagrams. Sounds like it could be a bad ground, loose wire or the headlight switch. A VOM would help pinpoint the problem. Good luck.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-16-2006, 03:53 PM   #3
Ormly
Thanks Boxrodz.
Ormly
Old 09-16-2006, 03:57 PM   #4
msgross
msgross's Avatar
sounds like a ground or short, check the wires that touch metal (6 inches behind bulb) always prone to rubbing over time and short themself out on the body...
msgross is offline   Reply With Quote
