09-16-2006, 04:55 PM | #1 |
69 gmc no markers ?
i went to look at a 69 gmc 2wd short bed 6cyl 3spd had rear leafs and the stye markers with no bulbs in the m . the funny part i dont understand is the rear bed sides had no markers at all . the truck was supposed to be all original and it looked it . i am not up on my gmcs any input . note pics will follow if i buy it . I lost my digi camera .
09-16-2006, 05:03 PM | #2 |
Gone Fishing
Re: 69 gmc no markers ?
67 only had no side marker lights
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
09-16-2006, 05:19 PM | #3 |
18 Till I Die
sounds like a 69 front and a 67 rear??
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
09-16-2006, 05:45 PM | #4 |
how about the front markers ? no wiring for the markers ,it seems to be all original under the hood .has manual drums all the way around but it does have power steering .
09-16-2006, 06:15 PM | #5 | |||
Union Electrician
My 69 has the lens and no bulbs or wiring, the lens doesn't even a spot to put the bulb in.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
09-16-2006, 08:04 PM | #6 |
its all about the +6 inches
the bulbs were optional in 68 and 69, onless you had a cab chassis, then it was a federally required option, allong with the clearance lamps on the roof.
The bed is either modified, or a 67. The seller is either mistaken, or mistaken you for a fool. |
09-16-2006, 08:25 PM | #7 |
i wasnt sure on the marker light wiring part . the bed must have been changed the only clue i saw was a half doller size dent on the back of the cab that had beed filled and the filler cracked . it makes some sence the bed is the nicest one i have seen o rot some swelling near the rear cross member but even the floor is rot free . the cab overall is still very solid but will need the basics with a little patching on the firewall .its funny when you look at a truck and if there is a little or alot of rust you still wind up replacing the same panels sometimes just a little more than the other .
