09-17-2006, 12:12 PM | #1 |
Junior Member
4.8 to 5.3 swap
Has anyone here swapped a 4.8 to a 5.3 in their truck? I have a 2001 silverado that I am pulling motor out of for a family member. There is plenty of 5.3's out there in my area to be had, but not a whole lot to choose from in the 4.8's. Other than changing the pcm is there anything else that I need to consider when changing to the 5.3?
09-17-2006, 01:25 PM | #2 |
Re: 4.8 to 5.3 swap
you might check out ls1truck.com for some quicker info in this swap.
I plan on installing a 5.3 in place of my 4.8 when it goes out.
Youth soon passes away, but immaturity can last a life time. |
09-17-2006, 10:42 PM | #3 |
its just $$$$$
Re: 4.8 to 5.3 swap
I believe it would be a direct swap. the ECM should work also.
09-17-2006, 11:11 PM | #4 |
Insert Title Here
Re: 4.8 to 5.3 swap
computer and everything should work just fine... should be a direct swap.. but if your going through all the trouble of swaping why not go 6.0?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
09-17-2006, 11:11 PM | #5 |
Re: 4.8 to 5.3 swap
what about a 5.3 to 6.0 swap?
Meticulous Fabrications Milford Michigan |
09-25-2006, 03:10 PM | #6 |
Re: 4.8 to 5.3 swap
any 4.8 to 5.3 or 60 will directly swap in. You will probably need a custom tune for your PCM though i believe.
