Old 09-17-2006, 09:13 PM   #1
The Hogdoctor
Rear End
What is the Quickest way to find out the gear ratio, and if the rear end is positive traction when you are in a junk yard. I don't want to pull off the plates covering the diff. to find what I need. Is there a tag somewhere that I can get the numbers?
The Hogdoctor is offline   Reply With Quote
Old 09-21-2006, 01:01 AM   #2
89 crew
Re: Rear End
the first thing to look for is the tag under one of the bolts that says positraction gear lube only
89 crew is offline   Reply With Quote
Old 09-22-2006, 09:10 PM   #3
The Hogdoctor
Re: Rear End
Thanks , that will save me a lot of time.
Old 09-22-2006, 09:41 PM   #4
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: Rear End
no guarantee that it will still have one on it, find the rpo codes usually in the glove box posi is G80 on these trucks and say GU6 is 342 gears just for an example you can also do a search on gm rpo codes for those year trucks and you will find some more results as i have done this in the past hope i've been somewhat helpful
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
