09-18-2006, 01:57 AM | #1 |
71 Body to 88 frame
Anybody ever do a swap like this? I have a 71 that the running rear is getting real tired in and I just towed in ( I have a towing company) a clean 1988. Just wondering if it would be easier to just swap bodies? Probaly quite a few that would be different though.
09-18-2006, 04:06 AM | #2 |
67-72 parts finder
Re: 71 Body to 88 frame
why not just swap the running gear onto your frame, since you know everything will bolt up, suspension can always be rebuilt by the way nice lookin burban!!!!
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
09-18-2006, 04:50 AM | #3 |
Designated A-hole!
That's a good looking burb. I know the frames are way off on the pickups (I have a 90ish swb frame laying around and it looks totally different than my 70).
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-18-2006, 07:38 PM | #4 |
Wheel bases are different...........all depends on how much time and effort you want to put into it. Is the 88 straight axle or IFS? If it is IFS the brackets for the suspension are welded to the frame
09-19-2006, 05:18 PM | #5 | |
Old School, New Style
Springs and axle perches will be different. Also the axle lengths might be different. Of course axle lengths were different among the half tons and 3/4, 1 tons anyways among the later years. My half ton 86 Sub has a shorter track width in the rear as compaired to the front and it looks damn silly. Aaron
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
09-19-2006, 07:14 PM | #6 |
Very nice burb Kmontee,
1964 BBC 402 4x4 |
09-19-2006, 08:14 PM | #7 |
Its my rear axle and transfer case that are worn. Sounds like I might be better off just rebuilding my axles. What about the tranfer case? Would it swap?
I've built alot of Hot Rods but never any 4x4 stuff so I dont know much about them. My Vega: |
09-20-2006, 03:29 AM | #8 | |
What transmissions are in both of the Suburbans? Somebody correct me if I'm wrong... if they both have the same transmission the newer x-fer case and adapter should bolt up to the transmission in your 71. The linkage and maybe the driveshaft lenghts may be different. If I remember right, your 71 Burb should have an NP-205. I've heard they are not difficult to rebuild, and parts are pretty easy to find too. The NP-205 is a better x-fer case than what is in the 88...the 88 has an NP-208. The 205 is all gear driven and the np-208 is chain driven.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
09-22-2006, 06:00 PM | #9 |
The 88 is probably a 700r4, which would make a nice upgrade.
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 09-22-2006 at 06:01 PM. |
09-23-2006, 01:15 AM | #10 |
The 88 does have a 4 speed auto. with a 350 /throttle body injection. But I need to keep this project as simple as possably. I have to many other projects going. Besides the 454 in mine cruises on the hiway at 2400 rpm. has alots of bottom end with the 4x4 cam and headers. Would make a nice upgrade though.
Thanks for the info on the x-fer cases rcbildr. I will look into to rebuilding it. I never done one but there is always a first. (Takes me back to hi-school. Cuteist little blonde girl you ever seen.... ) Last edited by kmontee; 09-23-2006 at 01:20 AM. |
09-25-2006, 04:51 AM | #11 |
Yup, I'm comp-useless
kmontee, how long and where are you in the towing biz?
I have been at it for 17 years. BTW, nice 'burb |
