Painless Wiring Question
I have my 3/4 ton chevy wired with painless wiring. Nice kit but I have a question about the wiring for the alt. Does anyone have a diagram of how this should be wired? My old setup had two wires coming off the alt.
One wire going to the bolt off the alt. to the starter and the other went to one tab on the side (red). The white wire was not used. Hope this make since and sorry for no pics. Thanks for your help.
1972 Chevy Cheyenne 20 1979 Chevy Camaro 2007 Chevy Avalanche 2005 Mini Cooper |
Re: Painless Wiring Question
You can download instructions for your harness if summit racing sells the harness that you have. These instructions should have something to help you wire the alternator. The instructions will be in a pdf format.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
I have those but there was an insert I can not find for a high output alt. They did not have a wire being used for the alt terminals and I had a wire going from the starter to the alt terminal. The white wire from the alt terminal was not used. ??????????? hmmmmm confused and just need to wire it so it charges the system.
It's a catastrophic success.
![]() Join Date: Jan 2003
If it has an internal regulator then it should look like this.
Oilfield Trash
there should be a white whire in the kit #914, that goes to the alt. plug, red wire from the plug jumps to the post on the back of the alt, it will still charge without the white wire hooked up, but your gauge won't work. I can take a pic of mine if you want.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
blue85 - pics would be great
I have called MAD ELECTRIC the guy was very helpfull
99 nbs 5.3L x-cab Hypertech programmer True dual 1 chamber flowmasters magnaflow x-pipe 3" PA body lift 315/75/16 BFG All Terrian 15.3 @ 89mph 72' C20 402ci sc,lb in bed tool box, and new paint http://www.cardomain.com/memberpage/456511/1 |
