Old 09-18-2006, 04:44 PM   #1
Brian Ringer
Junior Member
Brian Ringer's Avatar
Longer front shackles?
I saw a company selling longer front shackles for an additional 1.5" of lift. Has anyone done this or is it even safe to do? And also had a shorter rear shacke for 2" of lift instead of flipping the shackle mount.
DINGER!
Brian Ringer is offline   Reply With Quote
Old 09-18-2006, 04:50 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Longer front shackles?
The shackle would have to be 3" longer in order to gain 1.5 inches of lift. Check out Off Road Unlimited (google them, I don't know the weblink off the top of my head) they offer zero rate add a leafs/blocks for small amounts of lift. I wouldn't suggest longer shackles as a primary means of lifting your ride.
see ten is offline   Reply With Quote
Old 09-18-2006, 09:26 PM   #3
HeavyK20
HeavyK20's Avatar
I agree with see ten. I think the longer shackles are actually intended to help prevent arched springs from hitting the frame under exteme compression.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 09-18-2006, 11:28 PM   #4
mike in mo
longer shackles on the back of the front springs will make put the front u joint at a bad angle. add a leafs are cheap makes for a bad ride new springs are the best way to go.
just my 2 cents
mike in mo is offline   Reply With Quote
Old 09-19-2006, 05:58 PM   #5
see ten
WTB this ad
see ten's Avatar
New springs are the best way to go if you can afford them. I used new springs front and rear when I did my K10. I have also used add a leafs, and yes they ride like dammit! The zero rate add a leaf is like a block, but it bolts together with the spring pack like an add a leaf. It's called zero rate because it doesn't affect the ride. I don't know how much lift they provide but I am pretty sure it is a small amount.
Old 09-24-2006, 04:19 AM   #6
al's71gmc
4 eyed fever
al's71gmc's Avatar
I've looked at the zero rates, and they gave you 1". They may come larger too.? Thinking of putting them on the front to lessen the rake.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 10-03-2006, 05:06 PM   #7
Senator350
Senator350's Avatar
add-a-leafs over 1" aren't supposed to be used for the front suspension.
only the rear.
RN U OVR
Senator350 is offline   Reply With Quote
