Old 09-18-2006, 08:10 PM   #1
matthufham
speedometer issue
i have bought a new speedo cable and housing, new speedo (the odometer messed up my last one) and i have messed around with the driven gear a few times.
the tires are smaller than original, they're 60 series on 15 inch rims. the transmission is a th350. the speedo drive gear in the transmission was yellow-ish so that means it's a 19 tooth. the driven gear i had was brown-ish and it should be a 18 tooth, i proved it was an 18 tooth because i counted. i bought a natural colored driven gear that is a 19 tooth.
with the 18 tooth driven gear my speedo read 10-12 mph too slow
with the 19 tooth driven gear my speedo reads 10-12 mph too fast
can anyone help me?
matthufham is offline   Reply With Quote
Old 09-18-2006, 08:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: speedometer issue
there's calculators on line .. I'll see if I can find a link, you'll need to know the diameter of your tire. 60 series tells you nothing without the cross section width too.
Old 09-18-2006, 08:21 PM   #3
matthufham
275s on the rear, i found one at tci but i couldn't get it to work.. it told me my tire height however is 27.99999 or 28 inches tall
http://www.tciauto.com/tech_info/speedo_gears.htm
Old 09-18-2006, 09:30 PM   #4
jacobs
jacobs's Avatar
Use a speedometer adapter. They are available from many sources including eBay.
jacobs is offline   Reply With Quote
Old 09-18-2006, 10:41 PM   #5
Longhorn Man
here's some reading and guidence for gears;
http://www.novaresource.org/speedo.htm
Old 09-18-2006, 10:50 PM   #6
Longhorn Man
Since you haven't mentioned your rear gear ratio, I'll assume your truck was originally a small block with automatic...
the formula for determining the proper gears for any application consists of multiplying the rear axle by 20.2, and dividing that number by the tire diameter. (rear axle x 20.2 / tire diameter)
Taking that formula...and my assumptions of your present gearing... we'll take 3.07 X 20.2 which comes out to 62.014. Now divide that by your 28 inch tall tires, and we get 2.21485714. Lets just call that 2.21.
Looking at the chart, there's a few ways to get the 2.21.
Old 09-20-2006, 04:18 PM   #7
matthufham
with my 3.73's i get an answer of 2.69, and the closest match is a 2.71. that calls for a 7 tooth drive gear and a 19 tooth driven gear (which i have). i looked for a 7 tooth drive gear and couldn't find one on tci's website, it went as low as 8 for a gm transmission. what's the deal
Old 09-20-2006, 04:26 PM   #8
Longhorn Man
take a look again, they list it there.
You can go to the dealer for these parts still, most places will have them on hand or get them pretty quick.
Old 09-20-2006, 04:38 PM   #9
matthufham
it's on their table that lists the colors designated to their teeth count, but wasn't on the table where you could buy them. i found a 7 tooth drive gear on ebay for a th350 for $8 bucks. i think i'm gonna "buy it now" since it's not too expensive. thanks for the help, i'll keep you updated.
