09-18-2006, 09:27 PM | #1 |
Oilfield Trash
Decisions, Decisions, What Engine To Build?
Since the 72 is done now, and about to parked for the winter, ive decided to start thinkin about more motor, was thinkin of an lt1 or ls1 swap, for power and mileage, then on the other hand a mild 402 build, then my other choice a 383 or 377 stroker, i could just to a wild 350 build, but that would be to easy. Any input? I really like the ls1, but i also like the old school carb and chrome look.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
09-18-2006, 09:41 PM | #2 |
I am a Referee of life.
Re: Decisions, Decisions, What Engine To Build?
Go for a stroked 400 turned into a 427 in a small block package.Big cubes from approx the same weight.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-18-2006, 10:16 PM | #3 |
Oilfield Trash
What crank/bore combo do you use?
09-18-2006, 10:16 PM | #4 |
How do you do that? Build a 427 out of a 400, you've got my attention.
09-18-2006, 10:24 PM | #5 |
I wanna know more too! What exactlly to you have to do to get a 427 out of a 400. I just acquired a good 400.
09-18-2006, 11:00 PM | #6 |
go with the LS-1 with a carb.............
09-18-2006, 11:17 PM | #7 |
turbo 454
09-18-2006, 11:22 PM | #8 |
M-O-N-E-Y.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
09-18-2006, 11:52 PM | #9 |
It's a 4" stroke in a standard bore (4.125") 400. If you go .030" over bore, it becomes a 434. It really gets expensive quick building these stroked 400's, and the production blocks aren't all that strong to begin with. The block needs to be clearanced, have to use a small base circle cam, the wrist pin gets pushed into the oil ring pack, and you should plan on some good flowing heads to take advantage of what you just put together. Those are a few drawbacks. The good news is they have great torque,can be made to look like any old 350, and they weigh less than a big block. Someone said it takes M-O-N-E-Y to put one together, he's not joking.
09-19-2006, 07:14 AM | #10 |
De stroke the 400 to a 377, and run the piss out of some rpms, put a little giggle gas on there and you will LOVE IT
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
09-19-2006, 11:51 AM | #11 |
My next build will be a 327 block with a 283 crank, balanced and blueprinted of course. Roller conversion, aluminum heads, Two small turbos, you get the idea.
09-19-2006, 04:07 PM | #12 |
09-19-2006, 04:37 PM | #13 |
6.0 LSx with a t56 or 4L60. Stock pullout motor with a cam swap and you have 400hp, EFI, and good mileage when you want to go easy on it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
