Old 09-18-2006, 09:43 PM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Front left disk brake is locked up
My truck has been sitting outside for about 6 months without moving and my front left disk brake is locked up. I drove it around the yard today and it seemed to have loosened up a bit, but is there anything else I could do to unlock it and burn the surface rust off the rotors?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-18-2006, 10:07 PM   #2
71SWBChevy
Post Whore
71SWBChevy's Avatar
Re: Front left disk brake is locked up
When I bought my truck I had the same problem, I never could get it to unlock other than temporarily. on the way home it would lock up everytime I stopped and would finally unlock again when it got to hot, but I was planning a frame off so I didn't care if it screwed up the rotor or anything.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 09-19-2006, 08:57 AM   #3
mkhutch
Throbbing Member
Same problem here with the left front. I ended up just doing a complete brake upgrade. I was reading a post here in the last few days though were someone said it ws caused by a blockage in the line where it attached. Hope this helps
mkhutch is offline   Reply With Quote
Old 09-19-2006, 09:06 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
Those loaded calipers are about $15 at Advance and should take about 20 min. each side. Should be a cheap way to find out if its the caliper and you will get fresh ones out of the deal. The last 2 times I had that problem it was the caliper.
72freak is offline   Reply With Quote
