Old 04-21-2002, 09:21 PM   #1
Dandeluxe
Dandeluxe's Avatar
Question alternator charging system ???
i put in an alternator with a built in regulator new from the auto parts store
and i put jumpers on the old voltage regulator plug-- red wire to blue wire to etc. get 12 volts from the ignition to the new alternator. and put the blue and white wire on the plugs on the new alternator. and still am not getting 13- 14 volts off of the new alternator. what am i doing wrong? i have done all that was said to make a reg. with a built in reg. work.?????? aahhhhhhh!!!!
1969 cst swb 350/400 th DANNY C. ddclux@aol.com st. louis mo.
for pic.s go to http://community.webshots.com/user/dandeluxeGO TO Fotki. com for public pic.s under DANDELUXE
I started out with nothing and i held on to it
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
Dandeluxe is offline   Reply With Quote
Old 04-21-2002, 10:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Did you take the ground from the harness and ground the case?
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-21-2002, 10:20 PM   #3
Dandeluxe
Dandeluxe's Avatar
Question
Andy, yes i did put the black wire from the harness and put it to the case on the alt. blue and white wire to the alt. and jumpers on the plug red to blue and brown to white on the harness plug to the old voltage reg. ????????????????????????????????????
Old 04-21-2002, 10:23 PM   #4
Dandeluxe
Dandeluxe's Avatar
Question
andy, blue wire to the top side of the alt. and white wire to the bot. plug with the new style harness for an alt.with a built in regulator. the alt. is new
Old 04-21-2002, 10:25 PM   #5
Longhorn Man
Post
Not quite folowing on the blug wires here...I put the blue wire to the red wire on the new pigtail..then the white to the brown.
you have the old reg harness done right from the sounds of it.
Old 04-21-2002, 10:35 PM   #6
Dandeluxe
Dandeluxe's Avatar
Lightbulb
andy, that is exactly the same way i did mine
maybe i got a lemon alternator ill check it out tomorrow. thanks for all your help though!! ill keep u posted. ok thanks, DAN
Old 04-21-2002, 10:53 PM   #7
Longhorn Man
Post
Check the back with a screwdriver...hold it by the center where the bearings are at. It should have a magnetic area while running it the thing isn't a turd.
Old 04-23-2002, 07:02 AM   #8
70c10
67-72 Addict!
70c10's Avatar
Exclamation
I got 3 bad alternators in a row last year. This drove me crazy. I wouldn't believe anybody that told me that, but I can tell you first hand it did happen!. Make them take your New rebuilt alternator out of the box and test it BEFORE you leave the store. I did this on the last one and have had no problems since.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-23-2002, 08:27 AM   #9
71Chev
71Chev's Avatar
Post
Are you checking it with the engine at idle?
Kick the rpms up a little, what does it put out then?
I too had a "new" alt that was bad. Just because a part is new, doesn't mean it's good.
  • 71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
