Rottenwood Garage Member
Engine code on my 68......what is it?
I have found the below info from the front # on this block V0607WA. I cleaned the grease from the back casting # and it has this...3914636.
According to my research it is a 307. I wouldnt be so surprised but i know its the original untouched engine and I thought only 283 and 327 had on oil filler tube in the front. This one has that filler tube. What do yall show the #'s being???? Did they put an oil filler tube on a 307? V-Flint 06-June 07- 7th day WA-307 Could it have the oil filler tube because this engine has that crazy emmisions/smog pump on it??? |
Re: Engine code on my 68......what is it?
My book shows several applications for WA, it was installed in 65,66,67 trucks as a 283. also in 68 trucks as a 307 with a manual trans an 2 barl carb. it was also used in 69 as a 350 truck motor and th400. HP was 175 for the first 3. 200 for the 307, and 255 for the 350. I hopr this helps.
![]() Join Date: Aug 2005
If it's original then it's a 307. I didn't think they were installing smog pumps that early though?
Yea....I asked that question when I drug it home and there were several board members that had them or had seen them. I know it came with this truck because it has an emmisions decal on the radiator support about the smog stuff.
#5 | |
That's a 307 2b style air cleaner you have there too.
My 68 327 4b has a ""Crazy" smog pump also. My 327 also has the oil fill tube similar to yours. From what I've been able to tell, 68 1/2 ton manual transmission trucks had smog pumps.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
What's that funky smell?
My original 68 307 (2bbl 3 on the tree) has the front oil filter, no smog pump and the same air cleaner as yours.
Mike S 68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck 3 on the tree, 307, No power brakes or steering Factory Options - HD rear spring and Ammeter/Oil Gauges My truck blog My Car Domain page |
72freak: what sites did you use to do your research and can you post the links to them please cause id like to do the same with my engine, thanks
dont mean to steal your thread..haha -steven
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
