Old 09-19-2006, 08:46 PM   #1
7387chevys
Trans swap Qs
What all would be involved with swapping a NV4500 5-speed O/D transmission inplace of a 700r4 in a 2wd 85 chevy?Has anyone done this swap(pictuers are awesome)? I know I would need a high hump trans tunnel,clutch master cylinder/slave cylinder and appropriate lines, clutch pedal is that all or am I forgetting something? Is the speedometer driven by cable or electronic? What would the approximate improvement be in gas milage or would that depend on engine?
7387chevys is offline   Reply With Quote
Old 09-20-2006, 12:52 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Trans swap Qs
Some info here. http://www.high-impact.net/transmiss...Configurations
I have never heard of that swap. You could probably raise your hump by using a bolt-in hump out of a 4WD truck.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-20-2006, 07:42 AM   #3
7387chevys
Re: Trans swap Qs
Yup 4wd hump would work. Would I have to move trans crossmember and would driveshaft length be different?
Old 09-20-2006, 09:22 AM   #4
Slonaker
Slonaker's Avatar
Re: Trans swap Qs
No idea, but if you can find the length of that transmission somewhere on the web, you could compare it to yours on this chart:
http://www.slonaker.net/images/truck/trans_lengths.jpg
Slonaker
Stock '01 Silverado
